JMB RetrofitsChris Nott
    Nov 2004
    103
    Coil Packs - Part Number
    Hi all,
    any suggestions on what the difference is between these two Coil Pack part numbers -
    07K 905 715F - what model is this one for ?
    06F 905 115F - original S3 coil pack
    are both suitable for 8P S3 ? I did search about but couldnt find much about the 07K - only that is used on A4 20T ?
    Nov 2004
    103
    Finally found the answer to this (just in case anyone needs this info in future) -
    Turns out the 07K part is the replacement for the original 06F part - both compatible. I usually expect a revision suffix but not the whole part number - sounds like thats what they did though.
