Sky InsuranceAH Fabrications
Thread: 2009 S3
    320
    2009 S3
    Should the S3 have a flashing alarm light when locked and should it beep when set?
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    it should flash but the beep i had mine turned on with vagcom just to beep when alarm set not sure about the 09 if it doesnt already id say the same vagcom to turn the beep on if you want it on that is i forgot everytime i locked my car weather i did or not with in like 3 seconds due to medication im on ...
    now i hear the beep and know its locked for sure
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Why have you started another thread?
    S3 Alarm
    8P2 S3
