Chris NottSky Insurance
    Jun 2009
    12
    A3 8P wheel bolt measurements?
    Hi all,
    I've decided to put on a set of BBS VZ033/CO 18" wheels on my Sportback, and would like to find out if anyone knows the measurements of the stock wheel bolts. Will these work with the BBS CO's? I think they have 17mm heads, but are they 12 x 1.5 threads, and how long are the stock bolts?
    Thanks in advance for any advice
    May 2009
    south yorkshire
    563
    27.5 mm
    Jun 2009
    12
    Thanks! Are they 12 x 1.5 or 14 x 1.5 with 17mm heads?
    Oct 2008
    Telford
    2,484
    This might sound a bit obvious but it only takes a min to take one out and have a look!
    They are generic to all VAG cars though it seems. Every VAG car i've had uses the same bolts. Cant see why there would be a problem on the BBS wheels.
    B6 1.8T Avant s line gmbh
    Jun 2009
    12
    Forged lightweight A3 wheel bolts
    Would anyone know of any aftermarket forged wheel bolts in the standard size for the A3?
    I know that Japanese tuners have a lot of forged wheel nuts, but have come up empty in my search for VAG forged replacement bolts. All I've found are H&R, not sure if these are forged, though.
    Any help would be appreciated.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Why not ask this question under the thread you have already started?
    EDIT: Moved
    8P2 S3
