Monster MotorsportBadger5
Results 1 to 11 of 11
    Jun 2009
    22
    Instrument lights flick on and off
    when i turn my lights on the Instrument lights somtimes flick on and off, when i try to adjust from the dimmer it doesn't work very well. i had this prob on my MK1 golf which was sorted after i fitted a new dimmer switch.
    has anyone else has this problem and know the fix ?
    I don't have auto lights.
    2.0 TDi Sport - 18" 2009 s-line wheels - Eibach Pro-Kit
    DeckedS3's Avatar
    Apr 2008
    South East
    551
    Is it more of a dim up and down? when you go through trees or something?
    Mine does it when direct sunlight hits the cluster (my main beams don't turn on) sometimes the speedo numbers dim up and down and the needle remains lit. If thats what your talking about it's suppose to do it....
    Hope that helps
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
    Jun 2009
    22
    not a dim up and down its a sudden on off as if there was a loose connection.
    Sep 2006
    383
    Quote Originally Posted by DeckedS3 View Post
    Hope that helps
    Good its not just mine then,numbers dim but the needles remain lit and yep damn tree shadows on a sunny day
    Felix A3's Avatar
    Apr 2008
    23
    I had the same problem with mine. Turned out to be a dry solder joint where the main connector for the rheostat attaches to the circuit board. If you remove the main lighting switch from the facia you can then detach the rheostat (dimmer switch) from it, carefully take the rheostat apart and re-solder the connections on the board. Re assemble and voila!
    Jun 2009
    22
    just noticed this happens with the lights off too
    Oct 2008
    Leeds
    142
    Quote Originally Posted by yani View Post
    OMG I just logged in to put a post like this on!!!
    my numbers dim under trees too, but not all the time. I think it's supposed to be a some kind of auto dimmer thing. But the needles don't change, just the dials. weird.
    Anyone know more about this. I'm just going to plug vagcom in and see if there's a fault.
    S5
    Silver, black leather, AMI IPOD - HDD, SATNAV - PHONE, PARK PLUS, ETC ETC ETC
    Jun 2009
    22
    mine has no auto head lights, the dash lights just flick on / off like its a loose wire, never noticed it dim. being day or night headlights on or off makes no diffrence.
    defo a loose plug or somthing..........
    Felix A3's Avatar
    Apr 2008
    23
    Is your instrument backlighting usually on all the time, irrespective of whether the lights are on or not?
    pns2007's Avatar
    Nov 2008
    627
    You can change this using VDS coding so that both needles and backlights stay on all the time. I had the prblem that with my roof down and the glare the cluster looked a bit dull, so I changed the settings so its on all the time
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Nav screen changes brightness with the ambient light too.
    Yani, try giving the area around the dimmer switch a couple of bangs, it may show more symptoms.
    8P2 S3
