Badger5JMB Retrofits
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By pns2007
Thread: Interior Light Pack on A3 cabriolet
    pns2007's Avatar
    Nov 2008
    627
    Can anyone supply a picture of the ambient lighting in the centre roof console by the map reading lights. I would like to retro fit but am unsure where they should go.
    Thanks in advance
    27,096
    They sit about 1cm from the front of the plastic trim, just ambience lighting above the gear area Neil
    You could pull down the light assembly & see if its got holes marked on the inside then you can gauge where they sit from this, sometimes they mould the units with markings for holes.
    pns2007's Avatar
    Nov 2008
    627
    I have taken the unit down and there are two holes. I from looking inside (the first picture) I think the area shown by the red arrows relate to the microphone etc not the lights. Looking at the second picture the holes shown by the red arrows relate to picture one. The area shown by the blue arrows are the alarm PIR's
    woodfloats likes this.
    27,096
    I'll have to check etka mate as I forgot you had a cab, dohhhhhh lol
    27,096
    Neil, would appear its gonna be a retro mod mate as etka isnt atm showing ambient lighting in the head unit for ther cab, you could use the same unit & just extend the wires to each led & drill some holes as the plastic isnt that hard & then glue the led's in place, could be done fairly easily mate, then just tag onto the illumination circuit.
    Jul 2012
    S4 cab map light
    Quote Originally Posted by pns2007 View Post
    I need to open my map light which appears to be the same on a 2007 cab S4. Does it just pry out with a flat head screw driver?
    pns2007's Avatar
    Nov 2008
    627
    If I remember correctly it does yes. But use a plastic flat tool as a screwdriver will mark the plastic
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
    downtothebone's Avatar
    Mar 2012
    Wimbledon
    214
    Sorry to hijack - is the bluetooth microphone supposed to fit into that light assembly?
