EM TuningAH Fabrications
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    Question s3 quick question
    quick question: does your rev needle stay right at the 800rpm (where it should be) or it goes little bit higer or lower (for a needle width)? is this thing normal?
    thanks for help
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    Oct 2008
    888
    mine goes to zero when l switch the motor off and away up to 7000 when l floor it. But at idle its usually about 800-900
    warren_S5's Avatar
    Oct 2007
    7,166
    nature of the beast. Despite the electronic idle stabilization function you will get a slight deviation in revs whilst at idle. It's vastly improved from 10+ years ago where cars of this nature would have seen quite some fluctuation.
    Completely normal, and if you mod it you may see a scrap more movement.
    Audi S5 3.0V6T Coupe Black Edition
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    Quote Originally Posted by dc240969 View Post
    funny guy mine goes 7200 when i floor it
    thanks warren
    Jul 2009
    Perfectly normal, the ECU can ramp the idle up a bit to compensate for the aircon cutting in or the power steering taking extra power from the alternator.
