Results 1 to 10 of 10
    just017's Avatar
    Apr 2009
    438
    How can i fix these fault codes
    Tuesday,30,June,2009,20:19:04:59303
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
    VIN: WAUZZZ8P66A048797 Mileage: 83410km/51828miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 15: Airbags Labels: 8P0-959-655-94.LBL
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H12 3720
    Coding: 0071602
    Shop #: WSC 00613
    6 Faults Found:
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
    011 - Open Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 77505 km
    Time Indication: 0
    Date: 2008.11.19
    Time: 13:14:49
    01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 77505 km
    Time Indication: 0
    Date: 2008.11.19
    Time: 13:14:49
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
    002 - Lower Limit Exceeded - MIL ON
    Freeze Frame:
    Fault Status: 11100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 77505 km
    Time Indication: 0
    Date: 2008.11.19
    Time: 13:14:51
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 77505 km
    Time Indication: 0
    Date: 2008.11.19
    Time: 13:14:52
    00588 - Airbag Igniter; Driver Side (N95)
    001 - Upper Limit Exceeded - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100001
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 77814 km
    Time Indication: 0
    Date: 2008.11.21
    Time: 11:35:33
    01587 - Igniter 2 for Airbag; Drivers Side (N250)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 77814 km
    Time Indication: 0
    Date: 2008.11.21
    Time: 11:35:33
    Any help appreciated along with my stuttering idle noise.
    PS, these faults dont bring up any driver warning lights
    Regards
    Audi A3 2.0TDi S-Line - Bose - AMD Remap - Pipercross Performance air filter - RNS-e Retrofit - RS4 style Alloys
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    I vagcomd a golf i went to buy and it had these faults:
    5 Faults Found:
    01366 - Opened Due to Crash Signal
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01616 - Signal Wire to Interior Monitor
    36-10 - Open Circuit - Intermittent
    00955 - Key 1
    09-10 - Adaptation Limit Surpassed - Intermittent
    They meant it had been in a crash...
    I think yours is the same and the airbig and seatbelt has tensioned (there's a small explosion in the tensioner which tightens it and lets go afaik)....
    Did you clear it and did it come back ?
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Those faults should bring on the airbag light at a minimum. Does the airbag light come on for a few secs and go out when you switch on the ignition?
    just017's Avatar
    Apr 2009
    438
    Yeah the car has previously been in a crash.
    Yeah, when i turn he ignition on, below the radio, the light that says passenger airbag is on comes on and goes off once the engine is started.
    just017's Avatar
    Apr 2009
    438
    Yeah i cleared the codes and they came back
    just017's Avatar
    Apr 2009
    438
    Anyone else experienced these codes?
    kaz219's Avatar
    Jun 2008
    1,796
    i think to clear the first 2, you may need crash sensors for the front.
    Were they replaced after the crash?
    Vagcom'd too
    just017's Avatar
    Apr 2009
    438
    Ahh right ok, is anyone able to post up the part numbers for those 2 crash sensors?
    I'm not sure if they were replaced as the crash was 3 owners back. So does that mean if i do have a crash, the airbags wont deploy?
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    Yes the airbag system will be in-active - however I would also expect the airbag fault light to be illuminated all the time to let you know.
    It may be that some kind of cheap repair / re-program has taken place on the Airbag module as this has to be replace in the event of crash that triggers the airbags.
    I would recommend that you have the system diagnosed professionally as it is a safety critical system and doesn't seem to be functioning correctly.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    just017's Avatar
    Apr 2009
    438
    O s**t.
    There is no airbag light on the car. If any normal person who didn't diagnose there car they would never know.
    I think i'll get the garage to check it out.
    Cheers mate
