EM TuningJMB Retrofits
Page 2 of 2 FirstFirst 12
Results 41 to 76 of 76
  1. #41
    27,073
    You have 3.7, I've got 3.62, where'd you grab that from then, lol.
    So you need to check your wiring against the 09 wiring for a car that has the 30 byte module, so ask someone with a facelift car with xenons with the N module what there engine code & car info is so you can go through elsawin & compare, this should lead you to see wiring differences mate.
  3. #42
    Mar 2009
    120
    I just got it from torrents.ru
    That's kind of a long shot for me... Where do I get car info from a matching face-lift model (mine doesn't have xenons yet)
    Can I just fool elsawin and enter a higher year in vehicle enquiry?
  4. #43
    27,073
    You can ask anyone on the forum mate, they would be glad to help, you can enter what year you like but it needs the engien code really to pull up right info.
    You have yours so just need a comparison for a later model, then can check the illumination circuit wire by wire, whats your engine code & gearbox.
  5. #44
    Mar 2009
    120
    Engine code BWA
    Gear box JLW
  6. #45
    Mar 2009
    120
    I've been looking in elsa for 2009 model and wiring seems (a first look) different.
    Probably it need more than 3-4 wires to be moved
    Problem is that I have to take ALL of wiring and compare them (big thing for me )
  7. #46
    Mar 2009
    120
  8. #47
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Excellent thread guys. I am learning
  9. #48
    Mar 2009
    120
    So, I did some compairing some connectors G and E from 2007 and 2008 (Central Electronic Module - Coding) and the wiring are identical...
    Elsa doesn't separate clearly the models... It's says from May 2006 or for model 2007 onwards...
    For new models it says from May 2008. So an engine and gear box code from a 2009 model is useless.
    Will compare others connectors too, but I have a feeling that they will be the same...
  10. #49
    Mar 2009
    120
    I found Pin assignment, onboard power supply control unit -J519
    Connector A (11-pin)
    Pin 1: Terminal 30 right
    Pin 2: Dipped beam right
    Pin 3: Main beam right
    Pin 4: Fog light right
    Pin 5: Vacant
    Pin 6: Flasher front right
    Pin 7: Side light front left
    Pin 8: Flasher side left
    Pin 9: Terminal 31 left
    Pin 10: Electric fuel pump relay
    Pin 11: Terminal 50 relay
    Connector B (12-pin)
    Pin 1: Reversing light right
    Pin 2: Vacant
    Pin 3: Light sensor supply
    Pin 4: Fog tail light, left
    Pin 5: Brake light right
    Pin 6: Vacant
    Pin 7: Footwell light
    Pin 8: Vacant
    Pin 9: Side light rear right
    Pin 10: Rear right turn signal
    Pin 11: Interior lighting
    Pin 12: Terminal 58s
    Connector C (12-pin)
    Pin 1: Seat heating shut-off
    Pin 2: Brake light left
    Pin 3: Vacant
    Pin 4: Coming Home LED
    Pin 5: Vacant
    Pin 6: Vacant
    Pin 7: Vacant
    Pin 8: Number plate light
    Pin 9: Brake light centre
    Pin 10: Side light rear left
    Pin 11: Rear left turn signal
    Pin 12: Vacant
    Connector D (11-pin)
    Pin 1: Terminal 30 left
    Pin 2: Fog light left
    Pin 3: Main beam left
    Pin 4: Dipped beam left
    Pin 5: Terminal 31 right
    Pin 6: Vacant
    Pin 7: Terminal 15 engine relay
    Pin 8: Headlight washer relay
    Pin 9: Flasher side right
    Pin 10: Side light front right
    Pin 11: Flasher front left
    Connector E (16-pin)
    Pin 1: Side lights switch
    Pin 2: Brake light switch
    Pin 3: Vacant
    Pin 4: Vacant
    Pin 5: Garage door opener input
    Pin 6: Fog tail light switch
    Pin 7: P/N without interlock switch
    Pin 8: Dipped beam switch
    Pin 9: Vacant
    Pin 10: Vacant
    Pin 11: Light sensor input
    Pin 12: Coming Home potentiometer tap
    Pin 13: Fog tail light switch
    Pin 14: Assistance driving lights switch
    Pin 15: EC mirror non-dipping
    Pin 16: Light switch 0 setting
    Connector F (8-pin)
    Pin 1: Terminal 50 diagnosis
    Pin 2: Terminal 15 engine diagnosis
    Pin 3: LIN bus
    Pin 4: Terminal L-alternator
    Pin 5: Bonnet contact
    Pin 6: Reversing light switch
    Pin 7: Terminal 30 reference
    Pin 8: Terminal 31 reference
    Connector G (12-pin)
    Pin 1: Terminal 50 switch
    Pin 2: Hazard warning lights LED
    Pin 3: Rear window heater LED
    Pin 4: Terminal 58s potentiometer ground
    Pin 5: Vacant
    Pin 6: Rear window heater button
    Pin 7: Convenience CAN Low
    Pin 8: Convenience CAN High
    Pin 9: Hazard warning lights button
    Pin 10: Terminal 58s potentiometer supply
    Pin 11: Terminal 15 switch
    Pin 12: Terminal 58s potentiometer tap
    Connector H (12-pin)
    Pin 1: Vacant
    Pin 2: Vacant
    Pin 3: Vacant
    Pin 4: Vacant
    Pin 5: Vacant
    Pin 6: Vacant
    Pin 7: Vacant
    Pin 8: Vacant
    Pin 9: Vacant
    Pin 10: Vacant
    Pin 11: Vacant
    Pin 12: Vacant
  11. #50
    Mar 2009
    120
    Did some thinking... Can this be because I installed full interior led's with resistors?! Maybe they are throwing off the car electronics and "think" it doesn't have any ambient lights...
    Will replace with stock bulbs to see what happens.
    Unfortunately it got cold over here and can't check until spring...
  12. #51
    Khufu's Avatar
    West coast of Scotland
    5,693
    Quote Originally Posted by drsilviuro View Post
    Spring??? Where are you?
    I was really hoping you had this sorted, its way over my head!
  13. #52
    Mar 2009
    120
    In Romania It's kinda getting cold here...
  14. #53
    Khufu's Avatar
    5,693
    Ya big wimp! Scotland's quite a bit further north than you LOL
  15. #54
    Mar 2009
    120
    Yeah.. you got the big ocean to keep you worm When did you get 23 degrees F(-5 C) over there? We get in some nights 14F (-10C).
    Have you seen snow this year?
  16. #55
    Khufu's Avatar
    5,693
    urgh, sounds unpleasant!!!! -5C isn't too rare here but I'm on the coast too so little snow. I rememember watching Rangers playing a Ibrox and none of the toilets or stalls worked as they were frozen, even the Clyde was frozen over.
  17. #56
    Khufu's Avatar
    5,693
    bump?
  18. #57
    Aug 2010
    I am having this same issue with revision P after installing European tail lights on my American 09 Face lifted A3 and coding with ver 10.6.0. I'm not 100% sure that the coding alone caused the "flashing" symptom, but if it helps - the last coding changes I made were in byte 24 and byte 25. Has any progress been made on fixing this little "issue"? Also, if any more info is needed from me, let me know....
    Drew
  19. #58
    27,073
    I replied to your audiforum.us post.
  20. #59
    Aug 2010
    You know, I didn't even realize before posting there, but that thread is about a different control module (8P0 907 063 A). They're posting useful info, but not for my situation. You say that your "audi friends" helped you? Does that mean a buddy at a dealership? I'm getting close to going to a dealership nearby to see if they'll work me a favor for cheap...
    If I wasn't so busy at work for the next week, I'd be more active on this and call Ross-Tech and Oemplus about it. Maybe I'll wait...patience is a virtue right? Besides, it looks like a dance club in my car at night.
    Drew
  21. #60
    27,073
    So did you resolve your module issues?
  22. #61
    27,073
    Also that pin layout is missing I to L connectors that the relays utilise.
  23. #62
    Mar 2009
    120
    A little thread resurrection I bought a brand new central electric (8P0-907-279-P). I've got rid of christmas lights but now I have no ambient lights. Also headlight switch, ESP, TPMS, cup holder don't lit as well...
    Coding again was made with print screens of old one... Don't know if I should tick "speed dependent trunk lock active". Did they fix this?
    Any ideas? NHN?
  24. #63
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,608
    The labels would have only been corrected on an update of VCDS.
    Useful thread, shame couldn't pin-point the exact problem. I'm assuming you replaced the LED's wit the stock bulbs without any luck?
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
  25. #64
    Mar 2009
    120
    Yeah.. that was no luck... had reached a dead end with that
  26. #65
    Mar 2009
    120
    Update: Christmas lights are back
  27. #66
    Khufu's Avatar
    5,693
    you still having problems! I went for a k revision, had no problems. What headlight switch you got? If the light dimmer switch isn't wired/correct you won't get dash lights working.
  28. #67
    Mar 2009
    120
    I'm not sure what it's now, but will be buying this 8J1 941 531 G as I recently retrofitted bi-xenon adaptive headlights.
  29. #68
    Mar 2009
    120
    If anyone has wondered, this is the coding that 8P0907279 P module has from factory 008C5F040014108040000000000000000000FE075C02000000 0000000000
  30. #69
    Mar 2009
    120
    Breakthrough!!! I managed to get rid of blinking led!!
    I started from factory coding and changed one bit at a time, and found out why I had this problem. It was a tweak of mine, as I wanted my turn lights turned on at 15% all the time. (Cool little feature - sad to let it go)
    I've set it back to 128x1 and now it's perfect. I can put this to rest!!
  31. #70
    27,073
    Any ideas? NHN?
    No they didnt fix this yet.
  32. #71
    Dec 2012
    34
    Electrical Issue, Brake Lights/Taillights, PLEASE help! Fault 00988
    This seems like the most relevant thread to look for help. If anybody has a minute can you check out my post? I've been trying to fix my tail light issue for almost 2 years now. Please please, any help would be appreciated!
    UM Tuned | UM DSG Stg 2 | APR Stage K04 |APR Downpipe |APR HPFP | S3 Injectors | SPM Intercooler | Nuespeed P-Flow/Charge Pipe | RS4 FRV | RFD | KONI STRT/DG Eibach Springs | WALK | S3 Front brakes | Stoptech SS Lines | 20% Tint | Kufatec Bluetooth Pro Kit | Black Grill | Black Back Rings | Black Bumper Lights | S3 DSG Shift Knob/parking brake w/Silver stitching | S3 Flat Bottom Wheel | Osram DRL | S3 LED Taillights | 18" Matte Black Wheels
  33. #72
    Dec 2012
    34
    In case this ever happens to anyone else, I pulled my Central Electronics 09F unit and popped it open to find this!!
  34. #73
    Dec 2012
    34
    I'm having the same issue, interior leds on my nav/climate control/door switches flickering like crazy. What does setting the turn signals to 128 do? Wouldn't it be set to 0 from the factory? Mine was set on 0 on my factory unit. Any other suggestions for me?
  35. #74
    msullx's Avatar
    Apr 2006
    Portugal
    9
    I'm having same issue...
    I did an update from 8P0907279F to 8P0907279N and my navy, steering buttons, climate, looks like an Christmas tree...
    Any ideas to solve the problem?
    msullx's Avatar
    Apr 2006
    Portugal
    9
    Just to inform that my problem was solved with the drsilviuro solution; bytes 7 must have 128 in those cases.
  37. #76
    Mar 2013
    Hi all,
    My climate control, radio and door switches look like a Christmas tree when lights are turned on...I took drsilviuro advice, this has stopped the flashing but I've notice if you set bytes 7 to 128 the dimmer switch does not have any affect on the led brightness, they stay bright.
    Anyone else found this to be the case?
