Volks AutosChris Nott
Results 1 to 11 of 11
    gixxer600k4's Avatar
    Feb 2009
    hampshire - UK
    686
    side repeater removal
    i have fitted lamin-x to my head lights and just got myself some more for my side repeaters. instead of me going out there and scratching my car, can anyone advise me on the easiest and safest way to remove them?
    thanks guys!
    Oct 2008
    Telford
    2,484
    I can get mine out with my fingers, just push the repeater across to one side and pull the other end up and out, the end that comes up and out is the one with "E" written on the lens in a circle.
    B6 1.8T Avant s line gmbh
    Feb 2009
    hampshire - UK
    686
    do i push it left or right? does it then go lose and slide out?
    Oct 2008
    Telford
    2,484
    Whether its pushed left or right depends which way it has been put in, If you push it towards the end which doesnt have the E on the lens it can then be pulled out, at no time does it become loose.
    Feb 2009
    hampshire - UK
    686
    lovely, cheers for the help mate
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    push them both towards the front of the car
    Feb 2009
    hampshire - UK
    686
    how far do you need to push them, they are moving about 5mm and then starts to feel really stiff, im worried about scratching the paint! do you need to get something in there to wedge it out?
    Oct 2008
    888
    is this the same way you would get access to change a bulb?
    Feb 2009
    hampshire - UK
    686
    yes it is, i managed to do it, i had to push it over to one side and with a plastic squeegee, wedged it out, now i know how to do it, it is very simple and safe. then there is a rubber sleeve that you pull out which houses the bulb
    Oct 2008
    888
    Ok that sounds fine. l have heard that there is another way to get to the bulb.
    Apr 2009
    Florida (previously Liverpool)
    655
    Quote Originally Posted by 10blazin View Post
    ...Not nessie-celery...
    -Depends how they've been fitted. Mine came from the factory with one side fitted the other way round... look for the marking as mentioned above.
    Keef
