Monster MotorsportEM Tuning
    just017's Avatar
    Apr 2009
    438
    Tighten inside drivers door handle
    Hey guys,
    Can anyone post up a guide on how to tighten the drivers inside door handle, it feels a bit more 'floppy' than the passenger side and as it gets used every day i think something behing it needs tightening up.
    Any help greatly appreciated.
    Audi A3 2.0TDi S-Line - Bose - AMD Remap - Pipercross Performance air filter - RNS-e Retrofit - RS4 style Alloys
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    It is connected by a wire which hooks into it.
    Im not sure if you can tighten it but may be worth taking a look by pulling the door card off...
    If the wire has strectched, that could be why it has gone floppy or maybe the handle itself could be at fault..
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    just017's Avatar
    Apr 2009
    438
    Hmmm, so the whole door card needs to come off, is this hard to remove/replace?
    Yeah i dont think its faulty, it just has a tiny bit of slack compared to the passenger side from regular use.
    Cheers for your reply
    kaz219's Avatar
    Jun 2008
    1,796
    Door cards pretty easy to pop off
    Take off the trim (piano black or silver one)
    I think there's 5 screws under there - 2 at the top, 3 under the trim
    Then theres 1 or 2 screws at the bottom of the door card.
    Then pull !!!
    I start from the bottom corner, then do the bottom, thne the sides and it pulls off.
    There is a connector plug which you have to take out once the door cards off(theres a pink clip whch pulls up) and the cable which goes to the door handle...
    HTH
    Vagcom'd too
    Khufu's Avatar
    West coast of Scotland
    5,693
    it could be the plastic clip the bar attaches to at the lock mechanism is worn. Had this on my old A3, somtimes it would pop out and I'd have to strip the door to put it back in!!!!
    just017's Avatar
    Apr 2009
    438
    Ahh i might do that this weekend then and get my drivers door sensor fixed at the same time. Think one of the cables might be a bit loose as the drivers side rarely shows as open.
    Cheers for your help guys
