Chris NottSky Insurance
Results 1 to 15 of 15
    May 2009
    West Yorkshire
    1,609
    Engine Modifications, 2.0L TDI DSG.
    Are there any engine modifications which i can do to my 2.0L TDI to make it perform better? IE more responsive etc..
    I'm wanting to prepare it for a remap, I'm thinking about putting a decat pipe on, maybe get rid of the EGR valve? Can this be done on the 2.0L PD's, i know it could on the 1.9 TDI 130's.
    Would i see any difference in doing this mods? Are there any more which can be done?
    Any help would be appreciated.
    Thanks!
    Audi A3 2.0L TDI S-Line Sportback
    gixxer600k4's Avatar
    Feb 2009
    hampshire - UK
    686
    filter and exhausts with new downpipe, the downpipe is quite pricey i think tho but gives great gains. the remap will change the car a lot all other tuning you do will only be little such as replacing the DV for a forge DV putting a new, larger intercooler, fitting samco pipes
    May 2009
    West Yorkshire
    1,609
    A diesel motor has a wastegate, not a dump valve?
    What would new hoses do?
    I won't be going down the intercooler route, that would cost a lot of brass, don't really fancy changing the exhaust, that's why i mentioned decat, i assume the turbo would spool up quicker, maybe rev more freely? Would i get any warning signs on the dash?
    mikep's Avatar
    Jun 2003
    Wetheringsett, Suffolk
    591
    Just remap it, save your money until you see what the remap delivers.
    The gains from exhaust work and filters aren't very large. A brick on the accelerator can work well though ;-)
    Pragmatik ICT
    Revo (VAG & Porsche) & Steinbauer Dealer for Suffolk & N.Essex
    A3 Sportback 2.0TDi Sport DSG Revo Stage 1 & 2
    Porsche Boxster S Revo Stage 1
    May 2009
    West Yorkshire
    1,609
    Quote Originally Posted by mikep View Post
    Sounds like a plan!
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,767
    Just remap and change the filter to a panel filter - if you can afford it, get a cat back miltek and if you really want to, get the larger down pipe for it as well
    Is your car a 170 or 140?
    May 2009
    West Yorkshire
    1,609
    Quote Originally Posted by Boydie View Post
    It's a 140, noobish question but, what does a down pipe do and how much are they roughly? I don't want to fork out for a new exhaust, the one i have is fine lol, if i removed the car what overall effect would this have on the car?
    Boydie's Avatar
    Boycie
    Dec 2006
    4,767
    It comes off the turbo and down to the cat then onto the back box - just basically your full exhaust system!
    The new down pipe is larger!
    If you removed the cat? you will sound like a broken tractor!
    May 2009
    West Yorkshire
    1,609
    Ah, i see.. The cat will be staying in place then!
    Even though the down pipe is larger, what would this do though?
    Joe90k's Avatar
    Speed doesn't Kill!
    Apr 2009
    229
    Pull the cat off mate, trust me it sounds good. More like a jet engine with the amount of turbo noise. It's no louder in the car at all.
    Mine still has the cat but not for long. Got a full miltek going on with bigger downpipe and a panel filter.
    Joe
    Click above for my A3 Build thread!
    Feb 2009
    hampshire - UK
    686
    i was meaning diverter valve not dump valve!
    the samco pipes reduce heat transfer from engine bay into hoses and they are much stronger and don't buckle or split.
    the bigger downpipe along with exhaust and filter means the air is a lot more free flowing, comes in quicker and goes out quicker, not so much back pressure on turbo so it spools up nicely and doesn't slow down so quickly reduce turbo lag!
    if you do this before getting the remap, then the performance gains from the remap will be much higher as you can get that bit more boost!
    im not too sure about the cat, cat's nowadays are being built really well now and not very restrictive so gains may only be minimal, but better off asking someone who has removed their cat and see what they say!
    May 2009
    West Yorkshire
    1,609
    Thanks for all the replys!
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    I've got a custom turboback exhaust and I'm getting a custom map with a filter.
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    There is loads of things that can be done to the PD140 BKD engine but it all costs money. Just spend 300-400 on a good remap first and see if your happy. All this talk of changing the down pipe is total ****** and a waste of money for you.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    MarkSport's Avatar
    A3 2.0TDI 170bhp PhantomBlack
    May 2009
    Lisboa, Portugal
    127
    2007 Audi A3 | MB POWERED | ECS TAI | Eibach Pro-Kit | 6000k & Leds | Vag-Com Coded
    Custom DeCat Exhaust 2,5'' | Nitroplus | RNS-E w/2010 AN
