Volks AutosBadger5
Results 1 to 11 of 11
    bentleyboy
    Air con immediate on/off???
    Is there a way to turn your air con on or off without having to repeatedly tap the + or - buttons??
    Annoys me when it's on full blast and want to turn it off but have to press the - button 20 times before it finally switches off! And vice versa for when it's off and I want it on full blast.
    Oct 2008
    888
    lm sure if you press - for a few seconds it should turn off.
    bentleyboy
    Quote Originally Posted by dc240969 View Post
    I thought I'd already tried that and it just came down through the blower speeds until it went off.
    I want it to just switch off straight from the blower speed that it's at, and switch back on to the same speed.
    But cheers, I'll give it a go again.
    Oct 2008
    888
    lf it doesnt work and it isnt in the handbook it might be doable through VAGCOM.
    bentleyboy
    Couldn't see it in the handbook.
    Pretty silly IF they haven't given us that function as standard though.
    Most things have a simple on/off button, don't they!!
    Oct 2008
    888
    that is true. lm not one for reading the handbook either
    Mar 2009
    West Yorkshire
    118
    The A3's don't have the ON/OFF button, so you have to go through the fan speeds.
    Audi A3 (2005) 2.0 TDI Sport Quattro (140/ST3) 8P2
    RNS-E (2009 Map) & Cruise Control Installed!
    Oct 2008
    Telford
    2,488
    The blower speed is dependant on the temp its set at. If you have it on too cold the blower is always on trying to cool it down. Try upping the temp a few degrees and you will notice the blower not going so mental.
    B6 1.8T Avant s line gmbh
    Mar 2009
    West Yorkshire
    118
    The best thing would be to turn AUTO off and then the fan will not go full blast when ever you change the temperature.
    bentleyboy
    Quote Originally Posted by Lee_R View Post
    The blower speed is only dependant on the temp when you've got it on auto. When not on auto it just blows out air at which ever speed you have it set to, regardless of the temp setting.
    Oh well, looks like my FSI is going to give me an RSI because of the amount of times I'll have to press the +/- button.
    Audi, very poor!!!
    Oct 2008
    888
    Dont dispair, as l said you might be able to do it with vagcom. give iggu, jamiekip or nhn.
