Results 1 to 9 of 9
    Jun 2009
    Audi A3 2.0T Odd Air Intake Sound
    Hi i just installed a K&N Air Intake for my 2006 Audi A3 2.0T Quattro.
    Picture after installation: http://i42.tinypic.com/2yopqwj.jpg
    I had already mapped my car to 242bhp, and have a Remus Power Sound exhaust installed.
    Today after the install of the Air Intake my engine makes a strange sound at 4k RPM. Above it its fine, below it its fine. You can hear the sound on the youtube video.
    http://www.youtube.com/watch?v=iqUdaXQ6dno
    I can not find any leaks in the pipes or connections.
    Any idea what this might be? The car drives fine, and performs well as far as I can tell.
    Thank you for your time.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Weird!! It sounds more like an electronic beep on the video.
    I'm pretty sure it's not supposed to make that noise though.
    8P2 S3
    Jun 2009
    its def not an electronic beep, its mechanical. sounds like someone is blowing a strange whistle or something. im clueless.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Might be the DV on its way out.
    8P2 S3
    Jun 2009
    Sorry, whats the DV?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Diverter Valve. Like a blow off valve but it's a closed system that is used on the 2.0TFSI.
    8P2 S3
    Jun 2009
    could it be something to do with this knob?
    http://i42.tinypic.com/25i6wi8.jpg
    i unscrewed this morning, and im not sure if it was tight all the way before. Im not sure what it does.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Not a scooby mate. Someone will be able to help eventually. The forum is a bit quieter at the weekends.
    8P2 S3
    Jun 2009
    hehe ok thanks for the help anyway.
