Results 1 to 28 of 28
    Joe90k's Avatar
    Speed doesn't Kill!
    Apr 2009
    229
    Cruise Control Retrofit Guide!! HELP I NEED IT NOW!!
    Hello as above, I cannot find it on the internet, I am at work but stuck now with no steering wheel. I need the cruise control retrofit guide PLEASE!!
    If you have it can you e-mail it to me at joe90k AT gmail.com
    Thanks in advance!
    Joe
    Click above for my A3 Build thread!
    pns2007's Avatar
    Nov 2008
    627
    e-mail sent mate
    Joe90k's Avatar
    Speed doesn't Kill!
    Apr 2009
    229
    Done it now! Thanks for the help those that e-mailed/PM'd me.
    Need to get it coded then all will be well!
    Joe
    May 2009
    West Yorkshire
    1,628
    Joe how easy is it to fit the cruise?
    Audi A3 2.0L TDI S-Line Sportback
    pns2007's Avatar
    Nov 2008
    627
    Well it took me 3 hrs the first time round and when I had to refit due to wrong part being ordered it took me just over half an hour. Straight forward job really so long as your careful. Amazes me how much Audi charge for this when the part itself in only about 45. You will need VCDs to progam the car afterwards
    aristides's Avatar
    Aug 2008
    Greece
    543
    Guys i did the Cruise Control retrofit myself (actually the blokes of AUDI did) and now i got an issue.
    After they put everything back together, when i turn my steering wheel there is some contact between the plastic and the back of my wheel. We already changed one lower cover but the situation got worse :S
    Any Ideas? Is it possible that they didnt put the stalk and the slip ring correctly?
    I am now driving without the plastic covers behind the wheel, since i found it dangerous having a wheel that gets stuck while turning!
    FOR SALE:
    RNS-e 2013 DVD, BK Version, NOT unit, DVD disc
    Steering ECU : 1k0 953 549 AH, ideal for Cruise Control retrofit
    just017's Avatar
    Apr 2009
    438
    If Audi done the fit i'd take it straight back to get it fixed.
    Audi A3 2.0TDi S-Line - Bose - AMD Remap - Pipercross Performance air filter - RNS-e Retrofit - RS4 style Alloys
    27,016
    Its fitted wrong mate, just take it back & get them to refit properly, you cant fit it properly & have these issues, its impossible, so they must have fitted wrong.
    aristides's Avatar
    Aug 2008
    Greece
    543
    I thought that since the ECU has the slots for each stalk there wouldn`t be a chance of wrong fitment.
    Let`s hope its just that, i was starting to think that my Steering wheel had the problem!
    FOR SALE:
    27,016
    Steering wheel can only go a certain distance back on the column so it cant get in the way full stop mate so you're correct its got to be something fitted badly, if they didnt clip the top/bottom trims together properly &......................
    Hold on just had a thought, maybe they stuck the trim bolts on the column before putting the trim on & the trim is being pushed out so it interfere's with the rear of the wheel, thats possible & tbh if this is the case, then its very very stupidly thick of them not to see this.
    aristides's Avatar
    Aug 2008
    Greece
    543
    That`s got to be it.
    The stalks pushing the trim out.
    The slip ring sits just right, so i guess the new Stalk with the cruise control sits wrong and pushes everything forward.
    Will check tomorrow and let you know
    Thanks again for your quick answer mate
    FOR SALE:
    Wai-Fan's Avatar
    Jul 2008
    New York
    523
    Visit Wai-Fan's Instagram Channel
    Quote Originally Posted by pns2007 View Post
    The cruise control stalk is only 45 quid???
    2006/2008 - 52 Peugeot 206 1.4 LX, Platinum Silver
    2008 - 04 Audi A3 8P1 2.0 TDi (140) Sport, Mauritius Blue
    2013 - 2010 Audi B8 S4, Quartz Grey
    pns2007's Avatar
    Nov 2008
    627
    Yes? Spoke to Stoke Audi, but decided to get my from local dealer. I asked for discount and got it for 44.67 + VAT
    Wai-Fan's Avatar
    Jul 2008
    New York
    523
    Didn't realise it was so cheap! Might get myself one!
    MikeSel^'s Avatar
    Systems Support Specialist
    Oct 2008
    Hull, UK
    554
    e-mail sent mate
    Any chance you can email me the guide? audi {at} mikesel.info
    The opinions expressed here represent my own and not those of my employer.
    76
    Dont suppose this can be done on an 8L as well?
    pns2007's Avatar
    Nov 2008
    627
    Hi, my e-mail has long since been deleted and I sold my A3 over 6 months ago and haven't kept anything - Sorry! One of my posts refers to Nigels post in June 2008 if you can find that !!
    Otherwise all I can find is this http://www.audi-sport.net/vb/showthr...ht=#post752734
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
    c_w
    1,061
    Quote Originally Posted by Wai-Fan View Post
    I rang a dealer and for the 8P at least you need a new lower steering column trim (for a 3rd hole), a control unit and the stalk itself.
    Now I know the stalk and column piece are essential but I wonder if the control unit is "optional" depending if the car alreayd has it there??
    JohnS3's Avatar
    Oct 2004
    3,021
    Your steering controller may be OK. Post in the Stoke Audi section for parts costs and Dave will let you know if yours is OK. You'll have to send him your chassis number though.
    pns2007's Avatar
    Nov 2008
    627
    Hi, I have the lower cowling if anyone wants it. It is the non cruise part but there is a faint mark which could act as a guide if anyone wants to try and cut it out and save some 's. Don't know what the outcome would be but its Free to a good home if you want to collect from Telford, Shrops.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    hi guys,
    i know this is an old thread but does anyone have the guide for retrofitting cruise control on the 8p? i am looking to do it but im not too sure how its done.
    also if anyone knows how to fit in the cruise wire as i am being told that i may not have the wire in my car?
    much appriciated guys
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    Hey guys,
    Just in case anyone else is looking for a guide, i have found this thread after hours of searching!
    http://www.audi-sport.net/vb/showthr...ht=#post765712
    I hope to be fitting in mine next month when the funds are there for me to buy a vag-com.
    hope it helps others out there who like me want to fit in cruise control
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    scottie123's Avatar
    Oct 2008
    1,888
    Have you looked on the vcds thread to see if there is anybody in your area? I would have thought there must be someone near to you
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    i always planned on fitting cruise never got round to it though i always saw more desireable mods and did without, gladly the s3 has it though!
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    Quote Originally Posted by scottie123 View Post
    Im sure there are some guys close to me but i know when i get my hands on the VCDS i would want to play with it for a few hours to test and see what i can do with it, plus i am making a little list of things i want changed on the car. I know i will be using the VCDS for loads in the future.
    You never know maybe i will be so good at it that i will be fitting in things for others here
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    Just came back from speaking to the parts desk at Bexley Audi...
    He doesnt really know of any retro fitting and was telling me how some things cannot be done so I just got the info i needed and left...
    Anyway so he says he is not allowed to give me part numbers but could give me prices on the parts i wanted which is stupid but here is what he quoted me:
    Cruise control Switch - 64.93
    Lower steering wheel trim for cruise - 27.46
    Are these prices ok?
    He says that is all i need as i already have bought the ECU. Oh btw he says i have the 'F' ECU which is the same as what i just bought. does that mean that i dont actually need the ECU i have bought?
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
  28. #27
    pns2007's Avatar
    Nov 2008
    627
    I had a new shape A3 (58 plate) and bought a new stalk after talking with the guys at my local Audi parts. Unfortunately it was the wrong part number and there was some confusion over it. Does your currrent main beam click forward to put on and pull back to turn off or is it push to turn on and the stalk returns to its normal position. If so make sure you get the right part. See the following link and the links in the thread that I have added. The part numbers are in there
    http://www.audi-sport.net/vb/showthr...-a-new-2009-A3
  29. #28
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    thanks for that mate but i have an older A3... 2005
    i had it checked at the dealers today against my Chassis number and they quoted me that price on the part. Might talk to Stoke Audi as we get discount there
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
