Help from Milltek Owners please
RobinA3
Well-Known Member
Gold Supporter
Cheshire
Need some help with the milltek system on the Quattro, ideally a cat back system.
The mid section which joins the back box to the standard cat section i need to know what type of joint it is, does the mid section slide onto the cat section and is clamped or does milltek supply a seperate joint clamp thing with the exhaust system?
It's just a slip joint with a standard clamp that bolts up. There's actually quite a bit of adjustment so fitting is fairly easy.
