Sky InsuranceChris Nott
Results 1 to 33 of 33
    Mar 2009
    Leicestershire
    100
    RNS-E installed and now some questions....plus some kufatec bits for sale
    Ok so the Nav turned up last week and it turned up without connectors so I ordered the harness etc from Kufatec which turned up today.
    So I went outside to fit it. Now I have a concert III stereo and little did I know that I didn't actually need the harness nor did I need the removal keys (identical to the wife's ford ones). It really is a doddle to get in if you have a double DIN stereo. I had done all the reading up I could have done and taking the glove box out was easy. I opted for the receiver on top of the glove box based on the feedback on the forum, so far so good. I also did the pin switch as I have Bose, I also found this to be fairly simple to do and I think it sounds better as Audi intended
    So my questions are thus:
    Will using a copied DVD damage the RNS-E unit?
    How do I find out how many satellites it is seeing?
    It sounds like the fan is on all the time, even after about 15mins of the car being locked and ignition off, is this normal? A quick google search has made me think it might be a wiring problem.
    Is anyone interested in my surplus connections PM me if you are the Kufatec codes are:
    33408 Ariel adapter
    35682 Removal Keys
    33405 RNS-E harness
    Does anyone have a 2007 or later disc that would want to part with, again PM me if you have and name your price.
    All I have to do now is code the unit in. I have never used VCDS before so it is a virginal experience for me. Any top tips or pointers on what to do will be greatly appreciated.
    I would also like to say thanks to NHN and JohnS3 for their advice in other threads that have given me the confidence to try this out for myself.
    CHeers
    Olly
    Feb 2009
    118
    Nav
    Shouldnt make any difference
    Press NAV, then bottom right of the for buttons, this is titled Nav Info. Scroll up or down and you will see sat connections.
    My fan is on a fair amount, mines an 08 model, so not old at all, so would think this is fine!.
    Mar 2009
    Leicestershire
    100
    Thanks for that, went out for spin a little while ago and it the Nav seemed a little sluggish and not 100% accurate. I will monitor it over the next few trips and if it continues like that might re-seat the receiver.
    I velcro'd it to the top left of the glove box so it sits next to the airbag unit, if there is a better place then let me know and I will go an re-seat it.
    Olly
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    I think some folk mount the GPS antenna above the RNS-E (towards the windscreen I think) or behind the instrument cluster.
    Mine is mounted on top of the glove box and works fine.
    Jon
    Now A3 less......
    SiT
    Apr 2008
    Tyne & Wear
    98
    I was going to post a new thread but thought this one will do... good thread Olly btw
    I'm looking to get a Nav unit myself. I have 2007 S3 with factory MF steering wheel, Bluetooth, Bose & iPod connection.
    I understand the unit is pretty much a straight swap bar coding and Bose pin change.
    Question's is; is there anything else required..? reason for asking is i have bluetooth and hoping it is something to just 'plug in'..?! also, i read every now and then about a diversity antenna, i'm absolutley clueless with this suffice to say i like to listen to the radio so would it be degraded if i got the Nav without the diversity jobbie..?
    Any help appreciated
    Ta
    Sie
    Mar 2009
    Leicestershire
    100
    Hi, from what research I did it will depend on what your current stereo it. If you have a concert III (II+) like me then you won't need the diversity cable or the RNS cable either as all the connections are identical.
    What unit do you have?
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by SiT View Post
    Ta
    Sie
    Your car has a quadlock connector in the back of the present headunit. This just plugs into the RNSe when you fit it (just move the bose wire) all other pins are in the same place. You'll need to code the RNSe for the options fitted to your car or the phone & MFSW might not work, also code it for Bose to get the correct EQ settings and remove the Gala menu as it's not needed. Depends on the units current coding.
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by ollyhawkeye View Post
    Olly
    The map updates every 1 to 3 seconds or so. It's not real time so-to-speak. Did you code the unit for your wheel size? If not it will recalibrate it's self then you may see a more accurate display. What firmware is it running?
    JohnS3's Avatar
    Oct 2004
    3,021
    The physical connections are the same ie a double fakra plug. BUT the antenna systems are quite different. See my thread for more info, especially if you have patchy radio reception, as it shows you how to convert the antenna system from ii+ (HF/HF) back to RNSe (ZF/HF)
    Converting symphony II antenna system use with RNSe
    Mar 2009
    Leicestershire
    100
    Thanks for those John.
    I think I am going to do the aerial upgrade as whilst the reception is ok 90% of the time I think it needs improvement, may PM you nearer the time for help on that one.
    I have a question about the GALA though, I was sure that I coded my unit to work with audiopilot using the BOSE microphone, however the GALA menu is still there and the volume is quite erratic, how do I just turn it all off so I decide the volume?
    Finally I am getting the usual aerial fault codes but I am also getting an error on the right speaker. I will try and find the specific code when I get in tonight, but has anyone seen that before??
    Olly
    JohnS3's Avatar
    Oct 2004
    3,021
    If the GALA menu is still there the unit isn't coded properly. The unit should be 0xx9xxx for Bose and also adaptation channel 8 should be 255 for gala via microphone (audiopilot) You could leave it as is and just set Gala to 0, that might turn off the volume adjustments.
    You can turn down the effects of the audipilot system (when coded properly) in engineering mode, I've turned off the EQ change as I found it very annoying. I don't think you can turn audipilot off completely without rewiring the BOSE amp. There is a an Audi tech doc floating around about this.
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Having my RNSE fitted on Sunday but wont/dont have access (or expertise for that matter) to VAGCom.
    So, until I track a friendly fellow Geordie/Smoggy/Mackem down to help me with VAGCom (beer token exchange of course)....
    Are we saying that without the VAGCom coding my Bluetooth wont work?
    And the same for FBMFSW?
    And is the `pin move` for BOSE always necessary?
    car is 57 (07) with concert btw.
    Paul
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    JohnS3's Avatar
    Oct 2004
    3,021
    Depends on what the unit is coded for already, it may work, it may not.
    Bose pin is ALWAYS necessary.
    If you fancy a drive I can code it up for you...
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Quote Originally Posted by JohnS3 View Post
    Thanks John.
    The nav unit is coming out of Wizbits car so I will have to check what he has already.
    Any tools needed to do the bose pin move? Or even a `how to` anywhere?
    Might take you up on the coding offer if get stuck getting it done local.
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    JohnS3's Avatar
    Oct 2004
    3,021
    When you have the quadlock unplugged you'll see some locking clips which hold the 4 individual plugs in place. Once the seperate plugs are out you'll see how to get the pins out.
    and now the pic you're all sick of me posting....
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Cant see the pic though, for some reason Ive not been able to this last few days.
    Will try at home later.
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    Mar 2009
    Leicestershire
    100
    Paul,
    I found the Bose pin really easy. You dismantle the quad block connector and remove the outer casing from the blue connector. I then used my removal keys to get the pin out. You basically push the catch in and then slide the cable out. moved it over and everyone is happy.
    Olly
    Mar 2009
    Leicestershire
    100
    Yeh the Gala Menu is still there, but am sure I set up the audiopilot. I will check later though. Gala however was set to off in the RNS-e and it was still changing the volume all over the place.
    Would be interested in the engineering mode fix though, although I think I have just got to grips with VCDS so if its "advanced" I'm not confident that I wouldn't break something.....
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by PaulAr View Post
    Your IT police will have blocked access to photobucket.
    JohnS3's Avatar
    Oct 2004
    3,021
    Paul, You may find that you already have a wire in pin 7. It's safe to remove it, insulate it, label it and tape it out of the way. It's not needed on the RNSe.
    Mar 2009
    Leicestershire
    100
    Sorry to harp on about this. I have coded for bose now but it won't let me change the gala to audio pilot which is wierd.
    The following error codes come up in VCDS for the radio, not sure about the KM reading!!
    Any help would be appreciated.
    Friday,12,June,2009,15:21:46:16888
    VCDS Version: Release 805.4
    Address 56: Radio
    Control Module Part Number: 8P0 035 192 A
    Component and/or Version: RNS-E HIGH EU H70 0650
    Software Coding: 0209117
    Work Shop Code: WSC 01196
    7 Faults Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 37
    Freeze Frame:
    Mileage: 655350 km
    Count: 906
    Clock: 13:33
    00856 - Radio Antenna
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 37
    Freeze Frame:
    Mileage: 67470 km
    Count: 906
    Clock: 13:33
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 252
    Mileage: 67471 km
    Time Indication: 0
    Date: 2009.06.09
    Time: 13:18:09
    Freeze Frame:
    Mileage: 67470 km
    Count: 906
    Clock: 13:33
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 37
    Freeze Frame:
    Mileage: 67470 km
    Count: 906
    Clock: 13:33
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01111011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 206
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 206
    00857 - CD Changer Unit (R41)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 37
    JohnS3's Avatar
    Oct 2004
    3,021
    When you have coded for BOSE, you no longer see the GALA menu.
    You have some errors caused by fitting the unit and unplugging connections. You most likely have errors on other modules as you have had the CAN network unplugged when you swopped the headunit. Your coding is still wrong hence the error about the cd changer
    Anyway.... What options do you have in your car other than bose. Do you have a MFSW, phone prep or cd changer? Please post this info and we can get the coding right for you.
    Mar 2009
    Leicestershire
    100
    Thanks for this John, its much appreciated.
    I have a flat bottomed MF steering wheel
    iPod connection
    Bose
    I think that's it from the radio's perspective
    ~RS~'s Avatar
    Feb 2009
    1,463
    ollyhawkeye is this the adapter antenna you have?
    http://www.kufatec.de/shop/images/pr...ages/200_0.jpg
    Mar 2009
    Leicestershire
    100
    Quote Originally Posted by ~RS~ View Post
    That's the puppy
    ~RS~'s Avatar
    Feb 2009
    1,463
    Lemme check something, I may need that
  28. #27
    Mar 2009
    Leicestershire
    100
    no problem, its useless to me, as are the other bits. a sensible offer and its yours as I know the postage can be crazy from Kufatec
  29. #28
    JohnS3's Avatar
    Oct 2004
    3,021
    iPod connection
    Bose
    Code the RNSe to 0219117. That will turn off the speaker errors. Adaptation channel 8 on the RNSe should be 255.
    Clear the errors you have with vagcom and see how you go. You should only have the 858 ZF short to ground error as you have the wrong antenna system in the car.
  30. #29
    Mar 2009
    Leicestershire
    100
    Thats brilliant thanks John. The only error I am getting now is that the CAN is incorrectly coded and the aerial fault.
    How do I code my CAN properly, I thought I had that covered but obviously not
    Thanks again
    Olly
  31. #30
    JohnS3's Avatar
    Oct 2004
    3,021
    You need to code the can gateway to tell it the car has nav fitted. Open the can gateway with vagcom, I think you use the long coding helper you'll see a checkbox for navigation
  32. #31
    Mar 2009
    Leicestershire
    100
    Excellent, thanks John.
  33. #32
    Mar 2009
    Leicestershire
    100
    one final thing, it doesn't seem to have remembered the settings I inputted last night.
    Do I need to save them or am I exiting VCDS incorrectly?
    Thanks and sorry for being useless.
    Olly
  34. #33
    JohnS3's Avatar
    Oct 2004
    3,021
    There's normaly a "do it!" button, once pressed the coding is transfered and you get a coding accepted message. Might be worth setting the coding again, then going back in to double check it actually did it.
