Badger5EM Tuning
Page 5 of 6 FirstFirst 123456 LastLast
Results 161 to 200 of 233
Like Tree1Likes
Thread: Led Headlights on pre facelift?
  1. #161
    PregnantNproud's Avatar
    Gears of War
    May 2009
    Near Kent
    301
    Quote Originally Posted by influxsg View Post
    Back with some news, a friend of mine bought the head lights that Diggz was mentioning about, please note that my mate's car is a LHD as mine, now the leds don't seem to be more powerful then mines, the main difference between is that the ones from SONAR are better build than the no-name from ebay ( the ones that Diggz mentioned about).
    In conclusion the quaility of the lighting provided by the after market ones is superior than the lighting produced by the OEM mirror headlights.
    Cheers,
    ANdi
    Yea some pictures would be very helpful. Some at day/dusk/night.
    In other words, bumpety bump!
    "Its not so much that I set out to make an S3, its just I think the S3 is the best body kit for an A3."
  3. #162
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I have to say I reckon that these light don't seem to be worth it.
    My Dad has fitted a strip of LEDs to his headlights. They look great pretty close up and they're bright at night but the other day he was behind me and I could hardly see them. It can only have been about 10 metres.
    Saw a Landrover today with a bigger version and I could only just make them out too.
    Compared to the OEM ones they're very dim. I remember the first time I saw an A5 with them. It was in my rear view mirror, during the day and the A5 was over a mile behind me. Now THAT's bright!
    8P2 S3
  4. #163
    Gears of War
    May 2009
    Near Kent
    301
    Quote Originally Posted by Staz View Post
    II remember the first time I saw an A5 with them. It was in my rear view mirror, during the day and the A5 was over a mile behind me. Now THAT's bright!
    Those OEM's are truly bright arnt they! Everytime i see them in my rear view I know immediatley that they are real.
    But, wether diggz'z lights are the best reproduction or not, i'd imagine they are superior to led strips
  5. #164
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by PregnantNproud View Post
    I'm sure they are yeah. They look good on the pictures and they look OEM too. They're just not bright enough during the day to be worth it I reckon.
    8P2 S3
  6. #165
    AJames's Avatar
    Rally Driver - road Audi S3-8P
    Jul 2009
    Milan, Italy
    123
    So do you think that these would work with my factory xenon adaptive lights?
    http://www.d-edition.de/shop/KFZ-Aut...ht::84375.html
    2008 S3 8P: Forge DV, Twincooler, Short gear throw - CustomCAI - Full Milltek resonated - APR HPFP - PensoTech Custom Map - Sachs Racing clutch/cover assembly - NGK Iridium's - Bilstein B8's, tuned - Eibach ERS Springs- H&R antiroll bars - Bespoke Fixed WRC Camber Plates - Haldex Gen II & Switch - Tarox F2000 disks - Ferodo DS2500 pads - OZ Racing Gran Turismo LM 18" - Michelin PSport PS3's
    389bhp - 49kgm
    From Factory: everything but the sunroof.
  7. #166
    Gears of War
    May 2009
    Near Kent
    301
    Quote Originally Posted by AJames View Post
    This seller sells those same headlamps but bi-xenon. If they will work with your adaptive ones though is another question.
    Here
  8. #167
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Here
    Can they be set to RHD? I got lost somewhere!
    8P2 S3
  9. #168
    Gears of War
    May 2009
    Near Kent
    301
    I asked the guy in french and he said yes, they are for LHD and RHD.
    I'm not sure if the that means they can switched to RHD or if he sells RHD and LHD...
  10. #169
    Gears of War
    May 2009
    Near Kent
    301
    Very lights to meet you
    First off, don't buy these headlamps!
    So my friend Tony helped me convert these LHD's to RHDs. The best way to describe this process was fiddly like a b*tch.
    Got to thank SEM for the info! We drew round the cutoff shield and made a template. Afterward we cut the template out of a piece of alu and flipped and welded it onto the origional shield. We ensured the
    ----\ was exactly where the
    /----- was. So hopefully, that means we have a perfect RHD swap.
    Ok still some niggles:
    1. lights are WAY too high so gotta adjust the height with the switches tomorrow
    2. Lights seem to be aiming correctly and i drove for hours and no one flashed me. - Good sign!
    3. Of course, the beams must be tested at a garage to see if they really are RHD...
    4. The lamps are throwing errors on my dash. Namely: "LEFT HAND FULL BEAM" & "RIGHT HAND FULL BEAM"
    - I'm guessing this problem can be rectified with VAG-COM. Basically I need the car to ignore and headlamp errors as everytime I get this error message, there is no problem with the lights!
    I'll keep you posted on any new problems. Gotta love em.
    Please excuse the dirty car...
    I know these are terrible attempts at night shots... no decent camera...
  11. #170
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    great job and the healghts look very nice, from where did you buy them? Did you hae any prolems with the fting?
  12. #171
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I assume you had no errors before doing the mod? There's no reason why just adjusting that plate should do anything to the main beams. And the fact that it's on both sides is weird!
    Do the main beams actually light?
    8P2 S3
  13. #172
    Sem
    Sep 2004
    297
    Have to say, for aftermarket lamps they look pretty good. Could maybe do with some more LED's and swapping the orange indicator bulb for a silver/chrome one.
    What exactly did you weld the cutoff shield to though? They are bi-xenon type lamps hence the reason for the black solenoid, that should move another plate up and down when you fire up the main beam on.
    2008 (58) Audi A3 2.0TDI S-Line
    Phantom Black, Xenons, RNS-E etc...
  14. #173
    Gears of War
    May 2009
    Near Kent
    301
    Yea they do. And no, no errors before the mod. Not entirely sure whats going on there...
    Quote Originally Posted by Sem View Post
    Whats the black solenoid?
    I welded the template to the origional cutoff shield. Or, the little metal shield that moves. When its down, the beam is full. When its up, its dipped.
  15. #174
    Gears of War
    May 2009
    Near Kent
    301
    Ebay. The dude whos old it to me lied tho. He said they were RHD. They was not. So yes, they was a pain in the arse to fit! Still not sure they are perfectly RHD, but i'm inclined to use them anyway...
    Of course the main problem is the errors they keep throwing up...
  16. #175
    Sep 2009
    Hey there folk, i am new to this, just logged on, i have an A3 sportback 08' model, with Xenon lights, but i love the new lights, do you think that i could fit these on. And where on E-bay do i fiond these. You boys and girls in the UK and Europe are lucky man. Here in SA (South Africa) we are straved for great accessories
  17. #176
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    It's all in the thread.
    8P2 S3
  18. #177
    Gears of War
    May 2009
    Near Kent
    301
    Quote Originally Posted by Beetle Bhav View Post
    Hi there. Those lights i fitted are for left hand drive countries only. SO if that applies to you, your in luck! If not... you've got a bit of a job on your hands...
    Not only that but the lights make error messages pop up in your dashboard. I'm not sure if i got a dodgy pair or if its all of them.
  19. #178
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    (PregnantNproud)
    Do the Lights come on like they suppose too Like the Real DRL ? E.g. When you just start the car? You don't have to swicth the Side light on do you? That would be terrible....defeats the whole purpose of DRL.
  20. #179
    Gears of War
    May 2009
    Near Kent
    301
    Quote Originally Posted by digzz View Post
    (PregnantNproud)
    Unfortunately the led's only come on when you switch to sidelights. I'm not too bothered by that, but then i guess those are some of the prices you pay for aftermarket products. (wondering if they can be re-programmed with VAG...)
  21. #180
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    Any further updates on this thread ?
  22. #181
    Tommy's Avatar
    Makinen...ha
    Jan 2009
    Sheffield
    443
    In what way??
    He got them to work RHD...if thats what you mean by update lol?
  23. #182
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Quote Originally Posted by Tommy View Post
    In what way??
    How did he do that then? and is it complete?
  24. #183
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,806
    have a read of his thread A3 - S3 transformation (long...)
    Dark Vader Half sibling - MyThread
  25. #184
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Quote Originally Posted by benskin07 View Post
    I have read that already ...it don't say nothing on how he did it, or if it's even done.
  26. #185
    Tommy's Avatar
    Makinen...ha
    Jan 2009
    Sheffield
    443
    it does!!! im sure it does lol
    it even has after pics in it doesnt it?!
  27. #186
    Digzz's Avatar
    Jan 2009
    London
    1,383
    I'm talking about the LHD Lights To RHD ......I'm wondering if he has completed it how how he did it.
  28. #187
    Tommy's Avatar
    Makinen...ha
    Jan 2009
    Sheffield
    443
    post 169
  29. #188
    Digzz's Avatar
    Jan 2009
    London
    1,383
    post 169
    He does not state it was finished and he did'nt say it worked. The only thing it states is how he was going to try and do it. The only person that can say this is himself.
  30. #189
    Tommy's Avatar
    Makinen...ha
    Jan 2009
    Sheffield
    443
    Sour grapes! haha
  31. #190
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    That info is in THIS thread!
    8P2 S3
  32. #191
    Gears of War
    May 2009
    Near Kent
    301
    Sorry digzzz been busy. Mostly with disgruntled ebay members and with the car.
    The Lights were checked at the garage that did the respray with a headlight beam thingymajig. The machine told us that the headlamps were successfully converted from LHD to RHD.
    However, the beam was little small, eg it should be like this:
    \_______
    its like this:
    \________
    So yes, it is RHD but if it passes the MOT is another story. of course, if it fails, i'll just swap the aftermarket's with my OEM's. (For the MOT)
    HOW i did it is indeed explained above. (if u want more detail just ask) The only problem with the lights now are the error messages that only pop up when full beam is engaged.
    The car on the other hand is almost complete.
  33. #192
    Digzz's Avatar
    Jan 2009
    London
    1,383
    (PregnantNproud)
    If you want to change them low light LED'S in them lights you bought. There is a form on Audizine where fly300kts mods audi front lights and puts the best LEDs lights into the headlights for a fee. You can either send the lights to him and he would fit it....or you could get him to send the LEDS over and then you could install yourself.....check hes forms out:
    http://www.audizine.com/forum/showthread.php?t=292619
    http://www.audizine.com/forum/showth...=309948&page=2
  34. #193
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    But he is based in florida ..
  35. #194
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,806
    I like the FSI badge in the grill! Any more photos of the front end Rich?
  36. #195
    27,087
    Would you like to elaborate your comment a bit, because the adaptives have 2 motors built into each headlight for NESW directions, so if you mean will the linked headlights work with the current setup & keep bixenon adaptive working, highly unlikely given adaptive bixenons have a direct canbus connection & you'll get errors all the time & loose the directional workings of the headlights as they're not oem & wont talk to the car network/sensors.
    Personally they're one of the best mods I did to my car, oem bixenon adaptives, love them.
  37. #196
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Quote Originally Posted by crypric23 View Post
    It Don't matter....I've already asked him about it ...and anybody can send there lights via UPS or he can send you his Kit.
  38. #197
    Gears of War
    May 2009
    Near Kent
    301
    Yea man, theyre in the pictures section. Some better ones to come...
    I'd love to do that... there is a bi-zenon version of my aftermarket headlamp but i did not buy them. Though i figured the only difference between the zenon headlamp and the normal headlamp was the zenon bulb and HID kit within them?
    I could be wrong. The OEM bi-znons do look very good, mind
    The lens on my aftermarkets are so hard to get off i literally can;t see how i'd even remove them! That sticky black glue stuff is solid...
  39. #198
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,806
    Dont mean to sound cheeky but any way you could upload them on your build thread mate? For some strange reason i cant view the photo section every time i try to it closes down the window or my pc freezes
  40. #199
    Digzz's Avatar
    Jan 2009
    London
    1,383
    The lens on my aftermarkets are so hard to get off i literally can;t see how i'd even remove them! That sticky black glue stuff is solid...[/QUOTE]
    If you can't do it then...I would suggest to send them to him directly.
  41. #200
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,806
    Forgot to say use a heat gun to warm up the glue and then pull them a part.
    Do you know how much its costing to have them posted over to the usa and then back to the uk. And the fee of him fitting the new LED and the price of these bright LED?
