Sky InsuranceChris Nott
Results 1 to 13 of 13
    May 2008
    347
    Running staggered wheels on an s3
    Is it possible to run wider rear wheels on the s3? I heard that it may cause problems with the haldex if you do.
    I know that a few guys are running wider rear spacers which is in essence the same.
    GIAC, EVOMS, H & R
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    n8KOW ie aka nathen is doin the same on his a3 drop him a pm
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    I'm not gonna run different widths, I'm going to run different offsets, so it will appear wider.
    19" x 9J ET52 Front
    19" x 9J ET41 Back
    Should look
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    May 2008
    347
    Should look good but will it cause any problems with the haldex?
    GIAC, EVOMS, H & R
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Dunno I ain't got a haldex , not sure sohrob. Don't think it'll be a problem, as I'm sure RS4 owners with aftermarket rims will run wider rears.
    Aug 2005
    West London
    850
    I can see it causing issues with the haldex system when running wider wheels because the tyre diameter changes slightly with the different width and profiles. And the the difference between the turning radius of the front and rear wheels is one of the things that denotes how much the clutch pack opens or closes. If it doesnt damage anything which i doubt it will, it will certainly change how much power is moved aft.
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    I stand corrected
    S3 Big Andy's Avatar
    Stealth Beast Baby Yay
    Feb 2008
    Bramley Hants
    707
    If you run a heldex system then you cannot stagger the wheels as it puts stress on the whole quattro system and will in the end cause damage and be liable to loss of traction.
    Phantom Black, Revo, 450+ BHP , Milltek Evom's, Autotech fuel pump, RS4 brakes 18" Pro Race 1.2 team Dynamics, H&R ARB's, Bilstein PSS10's, Forge Twintercooler, GT3071R, RS4 Injectors, Helix racing clutch, Custom downpipe de-catted straight pipe to back box, 12.6second 1/4 mile! 4.03 sec's 0-60 This isnt just any car, this, THIS WAS the Stealth Beast!!
    Gone but not forgotten
    VCDS GONE TOO
    http://www.andyoram.co.uk
    Sep 2006
    surrey
    65
    Quote Originally Posted by N8KOW View Post
    19" x 9J ET52 Front
    19" x 9J ET41 Back
    Should look
    Will these even fit in the arch?
    I ask as i went to look at some 19x9's for my s3 with a similar offset and when i test fitted one the rim was touching the strut before actually touching the hub, this coud have been cured with a spacer but as the rim was already sticking out of the arch that was'nt really an option?
    S3-N's Avatar
    Feb 2008
    263
    Quote Originally Posted by Keith_S3 View Post
    I did exactly the same with some MK2 TT RS4 wheels, et52 19x9 - they touched the strut and with a spacer would stick out way to far. I had actually bought them and had to sell them.
    Phantom Black B7 S4 + Milltek
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Mike's Audi A3 wearing Bentley Continental GT Alloys, which are 19" x 9J ET41 on a 225/35/19 Falken 452, no spacers, and it cleared all 4 struts/shocks:
    So I might run a 5mm/10mm spacer if I have to. Making the fronts ET47/ET42 and the rears ET41. Either way they'll be on the car, that I can guarantee
    Sep 2006
    surrey
    65
    yeah i've seen this before but a 225 on a 9" rim! this is the same size tyre as the standard wheels' which are 7.5 or 8", not sure which,
    I drive my car to hard to be able to live with the negative affects this would have on handling with a stretched tyre,
    I have also read reports of rubbing with an 8.5" rim fitted with a 235 tyre,
    and the wheels in question that i was after fitting were the same as those in your sig.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Hi Keith,
    Thats fair enough, you have an S3, so I hope you drive it hard. My A3 is a diesel, so I'm quite chilled in it, don't drive like a LOONEY . I'm going to run a 215/35/19 on mine. As mine are for pure looks not driving pleasure! They will be fine for daily use and look like this:
