AH FabricationsChris Nott
Results 1 to 13 of 13
    RyanJonS4's Avatar
    Drive It Like You Stole It
    Mar 2009
    Oldham
    287
    Seat wont remember its last position.
    My sisters boyfriend has just bought a six month old a3. Whenever he tilts his
    seat forward to let people into the back, and then tries to put it back where it
    started, it slides all the way back and he has to re-adjust it to his normal
    driving position.
    To me this doesn't seem normal and would be rather annoying. Is there a
    problem with his seat or is there some sort of easy fix that has been
    completely overlooked?
    Thanks in advance
    RyanJonS4
    Milltek non-resonated cat-back - 15mm MTM spacers - Toyo T1R's all round - RS4 Pedals+foot rest - Blackout model front grilles - Custom black front badge - de-badged boot - R8 oil cap - silver indicator bulbs - Dodo Juice supernatural wax - ECS tuning Porsche cayenne brake kit ready to fit or sell?...
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    it used to happen to my 3 door it used to really pee me off .....
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I seem to remember from a loooooong time ago that someone found a catch under the seat somewhere which stopped it remembering.
    8P2 S3
    Matt's Avatar
    Jul 2006
    Cumbria
    1,416
    Mine does it. Always has done. Quite annoying. I make back seat passengers get in the passenger side door so I dont have to re-adjust my seat.
    Sold: A3 2.0 TDI 170 S-line | Full leather | BOSE | Phantom Black | Bluefin
    Now: Mini John Cooper Works
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Right found the thread:
    S3 Standard seat question
    8P2 S3
    Wai-Fan's Avatar
    Jul 2008
    New York
    523
    Visit Wai-Fan's Instagram Channel
    Guess I'm not the only one this happens to! At first I wondered why it felt different everytime I climbed into the car when I had to move it. Then realised the seat kept moving one notch further away from the steering wheel everytime I tried to put it back in place!
    2006/2008 - 52 Peugeot 206 1.4 LX, Platinum Silver
    2008 - 04 Audi A3 8P1 2.0 TDi (140) Sport, Mauritius Blue
    2013 - 2010 Audi B8 S4, Quartz Grey
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I now realise that we may be talking about different things.
    There's the problem where the seat won't recline back to it's original position (see link above) and there the "problem" where the seat won't slide back to it's original position.
    I use "s because it's user error as far as I can see.
    Basically when you slide the seat forward you need to make sure that the top part is pushed all the way forward and clicks before you try to slide the whole seat back.
    8P2 S3
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Happens with more or less all 3 door cars - take it back to the dealer to have a look!
    Mar 2009
    UK
    46
    These seats are cr*p for this. Mine has the same problem.
    I thought the old style seats in my 98 A3 were much better.
    2008 Audi A3
    2.0 TDI 170
    S-Line
    3dr
    Silver / Black Leather
    now with Sat Navigation, Cruise Control and Parking Sensors.
    mdre83's Avatar
    Aug 2007
    South East
    629
    Used to happen to me on my old A3. If you look under the seat you will probably come across a little metal black clip. This clips tends to pop off the runners for some reason or other. It acts as a stop from where the seat was last positioned. Re-fitting the clip should resolve the issue.
    However, if you cannot see/find the clip take it to the dealer.
    Hope this helped out... worked for me ;-)
    A3 8P2 2.0TDI S-Line 170 SB | Brilliant Red | Full Leather | BOSE | 6 Disc Changer | None Smoking Pack | Light Interior Pack (Converted to LEDs) | Rear Parking Sensors | S3 Air Vents | S3 Mirrors - Stolen!| S3 Pedals |
    Nov 2007
    Norway
    46
    Like others said, if you follow the instruction manual every time you shouldn't have this problem.
    I thought I had this problem, only to find out I was doing it wrong, the click is the important thing.
    Otherwise, leave it to Audi to sort it out - this should not be a problem.
    2008 A3 2.0 TDI S-line
    ADEY's Avatar
    Feb 2008
    Skegby - Notts
    245
    been my major gripe with my last 3 cars (2 a3's and mk5 gti)
    glad to read im not the only one!!
    A3 2.O TDI 170 S-LINE
    RyanJonS4's Avatar
    Mar 2009
    Oldham
    287
    Had a look in the seat runner in his a3 and there was a little metal clip thing at the back
    of it (cant think how to explain what it looks like).
    I pushed this forward a couple of inches then slid the seat back onto it, and it now goes
    back to its original position after its been tipped forward.
    Cheers for the advice guys.
    Help was much appreciated.
    RyanJonS4
