Well ive run some vag com logs and the most mine pulls is 1.3 bar which seems a bit low or is it cos the intake temps were 38 degrees? is there any way of checking the operation of the dv using the wastegate duty cycle figures in vag com?
Here's that thread I was on about Block - 1.3 bar with GIAC Hammer File:
http://www.vagoc.co.uk/vb/showthread.php?t=711&highlight=boost+giac&page=2
Hi
How do i read HP and Boost in my vag-com ??
I suppose as long as actual boost follows requested boost then it must just be how giac works. i'll check that next.
Hi mate just came across this thread , and i am thinking anout just changing my downpipe and cat and keeping the standard cat back exhaust and going stage 2+ , did you notice any noise increase in doing this?Intersting thread you've kicked off here Warren....
Anyway, Down pipe and custom centre - that'll be me then - and like said before, the DP and sports cats allow burnt gasses to be released more effectively reducing temp's... effectively better for the set up of the car. In terms of gains, it has deffo made a difference though, and remember I'm running the GIAC Hammer file which adapts as the mod's go on.
The car spools up far more effectively and gives 30lb/ft more torque from 2500rpm to 4000rpm and higher headline figures. Just goes to prove, you don't need to go to the expense of a full system.
I do think my car is torque shy though - always has been lower than many others
Really interesting that Revo say the CAI and Exhaust aren't needed... does beg the question what the purpose of the Stage 2 file is though?
