Volks AutosSky Insurance
Results 1 to 7 of 7
    LUPINN's Avatar
    May 2009
    16
    Exclamation Led in S3 Sportback
    I would like to have led in high-intensity in position 0 like in A5, Q5, A4 b8, etc.
    Is it possible?
    I have auto sensor lights and rain, so when i take auto position and it's a bit cloudy the xenon turns on. I don't want this, so I don't know how to do.
    in the position of parking lights the led's intensity is lower.. and it's not good to see
    I don't think it's impossible to do because every new audi has it!
    help me! thanks
    May 2009
    Hello guys!
    Nobody knows how to solve!?
    I am using the VAG, I tried in all ways to solve but is not the way!
    is possible, if you have the rain/light sensor, switch when you decide the DRL?
    Having the sensors and can only put on "auto" is the car that decides, not us!
    DeckedS3's Avatar
    Apr 2008
    South East
    551
    I don't know the answer to the question, but I know what you are trying to do.
    There may be an option in VAG-COM I'm guessing you could recode the light switch. I will have a go with mine when I get a chance.
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
    May 2009
    I tried in every way!
    I gave higher values to parking lights ... I have tried them all!
    These are all the bytes in the 07 coding of the "central electric"!
    Maybe watching all the options something jumps out!
    Maybe some data to be amended to increase the intensity of manually led!
    If you want in the meantime this is the procedure for disable the "winking" LED DRL...
    Click on SELECT
    09. CENT.ELECT.
    CODING 07
    LONG CODING HELPER
    GO ON BYTE 8 E "DISABLE" BIT 7
    May 2009
    No one has ideas, seeing the images?
    May 2009
    But nobody has this problem with the model 2009? you do not have the rain/light sensor??
    May 2009
    Through VAG I turned OFF the sensor, but has not solved anything!!!!!!
