Results 1 to 12 of 12
    Splathead's Avatar
    Dec 2007
    Suffolk, UK
    186
    GIAC Flashloader Users
    It is time for my S3's first service. This will be followed by a Remap. I will be going down the GIAC route. I was also going to buy a handheld flashloader but after looking at:
    http://giacusa.com/flashloader_handheld.php I'm having second thoughts.
    As I already have a genuine Ross-Tech cable, I have downloaded the PC software:
    http://www.giacusa.com/downloads/fla...r_full_105.zip
    Does anyone know if this works with the A3/S3?
    (I had a quick search for tis subject but could not find anything - sorry if it is repeat post).
    Present - 8V S3 3 Door S3 S-Tronic. Estoril Blue, LED Headlights, Super Sports Seats, Technology Pack, Folding & Dimming Mirrors, Interior Light Pack, Bang & Olufsen, Comfort Pack with Cruise Control & Rear Parking Sensors, Reversible Boot Liner, Tyre Pressure Monitor, Non Smoking Pack, Hold Assist
    Past "Highlights" - 2008 S3 (8P2), 2004 Alfa 147GTa, 1999 Fiat Coupe 20v Turbo LE, 1994 Astra GSi 16v
    Jamiekip's Avatar
    Jan 2009
    710
    Hmmmm, interesting that, I'd not noticed you could now download the switcher tool and do it from your PC.
    Personally, I like having the flashloader in the car... just incase I need to flash it back to stock immediately, for example, car breaks down and gets towed to a dealer.
    It just means I can be confident the map won't cause me any issues.
    Drop me a PM before you do your remap
    Splathead's Avatar
    Dec 2007
    Suffolk, UK
    186
    Cheers!
    Will Do!
    Oct 2008
    888
    Mmmmm. This is interesting. They have given us access to the flashing software on our PC. l wonder if it can be hacked to allow for other maps to be uploaded.
    Jamiekip's Avatar
    Jan 2009
    710
    I doubt it DC - it says on the web page that it allows you to swap between the purchased maps..... i'm guessing you still need a GIAC dealer to physically load the maps on the ECU
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    561
    From what steve at statller was saying GIAC america are very big on security hacking there files is near impossible,if you could get into there software you wont be far from getting into the pentagon in software skills
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I wouldn't be so sure on that. If the file can be read by software on the computer the software can be hacked to give the source code of the file.
    I'm not saying I could do it by the way! And I wouldn't want to, they earn their money.
    8P2 S3
    Oct 2008
    888
    Quote Originally Posted by Staz View Post
    l agree.
    Mar 2009
    82
    did you ever find out if the software with VCDS cable will work, as I am going down the same route, and only want the 'stock' map for services etc..
    thanks
    S3 Sportback; DSG, MRC, ITG.
    Splathead's Avatar
    Dec 2007
    Suffolk, UK
    186
    The software recognises my cable but then says 'can not find ECU' when plugged in to the car. I'm assuming because I have not had the remap done....... yet. So, it seems to work from that standpoint.
    What I don't understand is that I has assumed that the handheld flashloader stores the maps and flashes them to the ECU. However, with the software switch, where are the maps held? Or am I missing the point?
    Mar 2009
    82
    from what i understand, the maps/files are stored in the ECU (flash memory?) and the flashloader just 'points' the ECU to the address of the alternative file
    or something like that
    Jamiekip's Avatar
    Jan 2009
    710
    Quote Originally Posted by mnoble View Post
    Correct.
    Think of your ECU like a hard drive - the hardware is not bespoke to each model of car, but what's programmed inside them is.
    For exaple, I think the ECU on an S3, is the same hardware you'll find in a Focus (I'm sure I read that somewhere... anyway!).
    What this means is, within an ECU, all the standard programming may take up 70% of the available spacea s the hardwae is designed to work across all sorts of cars.
    What GIAC, Revo, etc do, is use the 'free' space in the ECU to add their programmes, all encrypted and 'hidden' from view.
    The flash loader therefore simply tells the ECU which programme to use.
    HTH
