Monster MotorsportChris Nott
Results 1 to 12 of 12
    MarkSport's Avatar
    A3 2.0TDI 170bhp PhantomBlack
    May 2009
    Lisboa, Portugal
    127
    Best Injectors for TDI
    In this case to replace Audi A3 170PS Stock injectors.
    What do you say ?
    2007 Audi A3 | MB POWERED | ECS TAI | Eibach Pro-Kit | 6000k & Leds | Vag-Com Coded
    Custom DeCat Exhaust 2,5'' | Nitroplus | RNS-E w/2010 AN
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Quote Originally Posted by MarkSport View Post
    What do you say ?
    If your looking for uprated injectors for more power. Bosio make some uprated nozzles but i do not know how much extra they flow. They are called PPD race nozzles 543.76 euro without VAT i was quoted from a Bosio dealer friend of mine. If you want more information best email mailto:info@dieselpower.cz
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,768
    543.76+vat :o
    How many are included in that price?
    Are they that good?
    Would they work well with only a remap and cat back exhaust?
    Feb 2007
    1,257
    Quote Originally Posted by Boydie View Post
    543.76+vat :o
    Are they that good?
    That is for four nozzles but you still then have to get a company to fit the nozzles in a set of PD170 injector bodies.
    Bosio make very good high quality nozzles. I have a set of P1287+ nozzles in my new engine build and the Race 783 nozzles for the PD130/150/160 engine have been around for sometime time and well provern. There would be no point fitting these to just a remapped car. You would need to have the DPF removed and fit a hybrid turbo before fitting these as the stock nozzles flow enough fuel before then.
    MarkSport's Avatar
    May 2009
    Lisboa, Portugal
    127
    And what Aftermaerket turbos? Where in Portugal, at 170PS i only had seen homemade prepared turbos nothing plug&play.
    Feb 2007
    1,257
    With DPF delete pipe and remap which cost about 700-850 fitted will see a claimed 220-230 bhp and 330ish lb torque. If you want more you need the PPD race injectors and a bigger turbo. If you want a plug and play turbo you can get the stock turbo internals enlarged to the same spec as a Turbo Dynamics stage 2 turbo as used on PD130/140/150/160 engines as it`s basically the same turbo but clocked at a different angle with a different manifold design.
    Stage 2 MD376
    Hi flow 2275 spec compressor wheel, cnc machined compressor housing, 360 degree thrust bearing, cut back turbine blades, lightening of turbine wheel for faster spool up, modified V.N.T. turbine housing, uprated turbine seals. Other blueprinting modifications.
    If you want anything bigger your looking at getting a custom manifold made to get the turbo to fit but any VNT turbo can in theory be made to fit all the way up to a hybrid GT3067V.
    MarkSport's Avatar
    May 2009
    Lisboa, Portugal
    127
    Quote Originally Posted by devonmikeyboy View Post
    Stage 2 MD376
    And how much gains with that?
    Feb 2007
    1,257
    TD claim a stage 2 turbo is good for about 260bhp with a GT1749V PD150 turbo used as a donor so maybe slightly more. I am surprised the PD170 turbo flows enough air to make 220-230bhp in stock form as it`s only a GT1749VC so like i said the internal wheels should basically be the same as a PD150 turbo. Maybe it`s just that the inlet and outlet are larger like the difference between the GT1749A and GT1749BB which makes the B produce more power then the A.
    MarkSport's Avatar
    May 2009
    Lisboa, Portugal
    127
    I have one friend with A3 170bhp, he have the same tuner as i have.
    With remap he does 209bhp.
    Without DPF and with direct line exhaust he does about 220bhp
    Now he puts a bigger turbo and a bigger exhaust direct line and does about 300bhp. (Intercooler, Rads and Clutcher also..)
    http://www.youtube.com/watch?v=DQKIHBVHZRk
    Feb 2007
    1,257
    If he is running 300bhp he must have bigger injector fitted surely as that car is smoking quite a lot. What turbo has he had fitted and who mapped it? If he is running 300bhp and a friend why are you asking us the questions as to how to tune the car?
    MarkSport's Avatar
    May 2009
    Lisboa, Portugal
    127
    I am asking about alternatives.
    He has a "homemade" prepared turbo, i dont know what model they use to produce that.
    The tuner is MB POWER. The same that does Allard racing cars few years ago and other racer teams.
    He havent change the injectors.
    S3 Intercooler, Radiators Oil and Diese, large direct downpipe, BMC CDA Intake, and GBS Rally Clutcher.
    May 2009
    south yorkshire
    563
    turbo dynamics quoted me 675 plus vat for a stage 2 hybrid only last week if the turbo i was sending in was a good 1 .
    i have found some ne else that has just made there first hybrid should be on the rr saturday for bhp figures etc
    quote 400 + vat for a swap
    i do however have a pd 150 turbo here was thinking of just swapping the full cassette over
    wouldnt mind fitting a bigger compressor wheel and housing first though
