Sky InsuranceChris Nott
    May 2009
    ESP Button Removal/Replacement
    Hi all,
    Apologies if this has already been asked but I have just bought a new ESP button and fascia surround (wraps around the cup holder, warning triangle and ESP/SRS Buttons).
    Would someone be able to tell me how to get them off without breaking/scratching any of the parts?
    Many thanks
    scottie123's Avatar
    Oct 2008
    1,888
    quite simple.
    the facia plate will just pull of by hand
    the switch is held in by a couple of plastic lugs. Just press these in and the old switch will pull out
    easy peasy
    05 SB SE BKD
    Build Thread
    27,087
    Open the cup holder, this then gives you some room to pull the trim of that surrounds the buttons, then when this is of give the esp button a slight tug, it should then come of so you can swap over.
    PS. Scottie check your PM's mate.
