JMB RetrofitsAH Fabrications
Results 1 to 22 of 22
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,969
    Is this ok steering heavier now its lowered?
    hi all,lowered my car 25mm on apex springs,fitted 2 new track rod ends and car drove ok,steering was a bit out,took it and had 4 wheel alignment,now car drives perfectly and steering is in the center,perfect!
    I have noticed steering has gone heavier than before (since 4 wheel alignment) is this normal? once lowered does it normally go slightly heavier? oh and ive had 18'' genuine s-line wheels.
    (if that makes a difference ,originals were 17's)
    Full leather/19"wheels/cruise/
    Apr 2009
    Sollentuna, Sweden
    86
    Well, it depends how heavier it has got.
    Normally yes it gets a more heavy feeling, but not that it should make you think about it.
    I went from 16" to 19" and it feels much heavier but still its not like it prevents me for driving like I did before..
    vw754's Avatar
    Nov 2006
    U.K
    1,969
    oh it doesnt prevent me from driving it,ive noticed it heavier but i was told if anything after alignment it goes lighter,i would like it a bit lighter thats all,its not stupidly heavy but u can tell
    May 2009
    south yorkshire
    628
    anyone with vag-com /vcds can adjust the sensitivity on the steering making it lighter
    i have 19" rims fitted and took the steering sensitivity down from 5 to 2
    i can feel the road now
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    i got 18s and its on 3
    vagcom should adjust to how you want it...
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    hatmeow's Avatar
    Turbo is the only way....
    Feb 2008
    247
    Quote Originally Posted by hollow View Post
    This only works for pre 2007 models. Those made after 07 have a different steering rack and cannot be changed.
    I think it really depends on the front / rear ratio of the height difference after the lowering. If the rear is lowered more than the front then the F/R weight bias shifts more to the back and the steering will be lighter and vice versa.
    A3 2.0T Sportback DSG.
    Engine / Trans:
    K04, Unitronic Stg II+ & DSG Stg II, S3 Injectors and Intercooler, APR F/Pump. BSH Intake, Forge DV, Oettinger Turbo Outlet, Eurojet throttle pipe, Milltek TBE. SP Meth Injection.
    Brakes and Suspension:
    Brembo 6 pot w/ 345mm slotted disks, TT front suspension, HPA Coliovers, OZ Palladio, 225/40/18 BS RE001
    Others:
    S3 Front, Pedals, & Mirrors, 09 SB Skirts & LED Rear Lights, Original HID retrofit, Oettinger Roof Spoiler. Defi Turbo Guage, FBMFSW
    vw754's Avatar
    Nov 2006
    U.K
    1,969
    mine was set on 8 and ive now set it on 9 and it feels great not too light or too heavy,i can still feel good feedback through the wheel........you guys must have a heavy wheel ......all you guys are 5 and below
    markwiggy's Avatar
    Third Gear
    Oct 2006
    North West
    1,123
    Surely changing from 17 to 18 inch wheels will make a difference to the steering as tyres fitted to the 18's will be lower and wider.
    Mark
    07 S3 Sprint Blue Now Sold
    12 Range Rover Evoque Dynamic Now sold
    A3 20 TDI S-Line Sportback in Daytona Grey with Aluminium Roof Rails, Fine Nappa Leather, Sat Nav, Comfort pack,Audi Sound System, Folding Mirrors, Heated Seats, Privacy Glass, Interior Light Pack, Non Smoke Pack.
    A4_DTM's Avatar
    Dec 2006
    Croatia
    97
    Is it possible to change steering sensitivity on S3 2008 ? It is too light for my taste, I can't feel the road proprertly, also it's so unprecise in corners. Can that be changed somehow ? I have VAG-COM
    S3 2008, GT3076R 0.64 @ 1.55 bar, custom tubular manifold, Milltek TB decated, Autotech FSI pump, RS3 intank pump, RS4 injectors, RS4 hp rail valve, custom Twintercooler, AWE CCB intake. Forge DV, Forge OCC, LOBA SMF Clutch kit // REVO stage 4 dyno tuned >> 441.4HP, 499NM // H&R springs. whiteline Anti-lift kit and rear 24mm ARB // WOT box // KEI force 10 gunmetal 18'' wheels // Facelift rear lights // tinted windows // LED interieur & exterieur
    Mar 2009
    Staffordshire
    1,238
    Quote Originally Posted by A4_DTM View Post
    I don't think so...
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    What presure are you running on your 18" wheels ?. I use F1's and they need 40psi all round. Pressure goes up with the width and profile.
    Feb 2009
    27
    Would changing the tyre pressure make a difference to the weight of steering . i am running 43 front at the moment and find the steering to light .
    Oct 2009
    Athens, Greece
    42
    absolutely it does...
    vw754's Avatar
    Nov 2006
    U.K
    1,969
    Im running 31/32 all round. its best to run near the same pressure as stated on the fuel cap.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    If you have 18 inch wheels mate check your fuel cap again...lol no wonder its heavy, your running on flat tyres..
    I run 18" 225/40s and the fuel cap says 2.5-3 BAR. unless you have an S-line i doubt your cap lists 18" but take it from me, 40psi will make all the difference.
    vw754's Avatar
    Nov 2006
    U.K
    1,969
    Quote Originally Posted by paddy View Post
    ive entered my car reg and a few others for sale on e-bay this is what i get.........
    Put ya reg in the link below and see what you get......heres a reg KP56 UNM
    ANYONE GOT A PIC OF THERE FUEL CAP STATING THE PRESSURES ?
    http://www.kwik-fit.com/tyre-pressure-search.asp
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    You want me to go out and take a picture !!!!!...............5 mins
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    low speed top fig.
    High sped/loaded bottom fig.
    Try 40psi and i think it will solve your problem..............and learn to trust people who answer your questions :-)
    vw754's Avatar
    Nov 2006
    U.K
    1,969
    low speed top fig.
    THANKS VERY VERY MUCH.........i went on the kwikfit tyre site they gave me 30 ish so i went off there........thanks very much again. MY CARS A SPORTBACK I GUESS THERE ALL THE SAME ? 5 DOOR/3 DOOR?
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Given that the SB is probably a little heavier at 38 to 40psi your erring on the right side. My advice would be to keep an eye on the wear over time but i dont think you will have any problems. i expect you fuel consumption to improve a bit as well and it should roll better of the gas.
    Let us know if it solves the steering /heavy problem .
    vw754's Avatar
    Nov 2006
    U.K
    1,969
    OK THANKS.......think if i get chance il go to the dealers and check the s-line sb on the forecourt .....make sure this time.
    vw754's Avatar
    Nov 2006
    U.K
    1,969
    Ive set it at 36 psi (front) and 33 psi (rear)
    Ive also adjusted the steering settings to 6
    They were originally on 8 when on 17" wheels/tyres when i changed to 18" i put it up to 9,now after the correct inflation i found it ok at 6 maybe could try 5 at some point but for now 6 is ok.
