Chris NottAH Fabrications
    May 2009
    SE London
    225
    remove headlamps
    does any1 know how to remove the headlamps, do you have to take the bumper of?
    thanks
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Yeah it`s a bumper off job and getting the bumper off is not a straight forward job making it a pain in the ass to do.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    gixxer600k4's Avatar
    Feb 2009
    hampshire - UK
    686
    yea you need to take the bumper off. there are three main screws just above the grill, leave them on till last, you need to unscrew all the ones underneath the front bumper and under the wheel arch. (you will need to remove part of the plastic arch lining as the are a two screw and one bolt each side, they are positioned on the side of the bumper where the top of bumper and front wings meet, bout half way between the wheel arch and head light) once these screw are out, come to front undo the main front three and it should come off easily. there are then two holes either side of each headlight, if you look down them, you can see a screw, i think u will need a star key for these. they are not screw as such, the headlight slots around these "screws" so just undo them slightly and pull headlight out, dont forget the undo the wiring loom!
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    8P2 S3
    unkle's Avatar
    Beer God
    Aug 2004
    Leics
    1,238
    Few tips:
    Jack the car up on both sides (safely) then put it on full lock this will give you enough room to work under the wheel arch, loosen all the screws under one wheel arch and the ones above the grill on that side of the car that you need to work on (There might be others Ive forgotten about its been a while) this will give you a bit to play with. Unclip the loom and gently ease out the headlamp then slot the new one in. If you prefer to take the bumper off just remember to have a blanket or cardboard to rest it on, stops it from getting scratched...
    I had to do this a few times dam BFG tests... :D
    Volvo V50 D5 R-Design
