Volks AutosMonster Motorsport
Results 1 to 16 of 16
Thread: 1K0 953 549 F
    edition's Avatar
    Nov 2007
    1,417
    1K0 953 549 F
    Hi,
    As some of you might have read i'm trying to retro-fit cruise control to my car.
    I have been told by 2 reliable sources that the module I have is not compatable.
    I have also been told that I don't need a new stering module!!
    Does anybody know the definative answer to my question?
    HELP!
    Khufu's Avatar
    West coast of Scotland
    5,693
    The correct module number is 8P0 953 549 F, Not sure if 1K0 953 549 F is. If you need to change the module, you will also need the relevent slip ring too.
    aristides's Avatar
    Aug 2008
    Greece
    543
    1K0 953 549 AH is also rumoured to work with cruise control.
    At least for MY08 models. What year is yours?
    I changed my module to 8P0 953 549F as i wanted to fit MuFu as well
    FOR SALE:
    RNS-e 2013 DVD, BK Version, NOT unit, DVD disc
    Steering ECU : 1k0 953 549 AH, ideal for Cruise Control retrofit
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    When I fitted Mikeys flat bottom wheel i noticed he has the 1K0 953 549 AH module (2006 car) along with this he had the correct slip ring which is needed for the 8P0 953 549F module, so if you do need the 8P0 version you should be ok with your slipring. sorry cant comment on if your module is ok. How about asking for VCDS logs of people with SE spec cars as they have criuse from factory, right????
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
    edition's Avatar
    Nov 2007
    1,417
    Cheers for that help!
    Anybody out there who can check there car?
    Tetbury Audi Parts Man
    Feb 2008
    Gloucestershire
    260
    An update regarding the launch of retro-fit cruise control for A3 and A3 Sportback.
    We are pleased to announce that retrofit cruise control is now available for the A3 and A3
    Sportback (please note that these kits are only suitable for 8P chassis numbers, not 8L). In order to ensure that this Audi Genuine Accessory is available across the entire A3 and Sportback range, there are 5 different specification systems that vary in price and fitting time accordingly. In order to correctly identify the system required for a specific vehicle, please follow the steps below:
    1. Identify if Navigation BNS (PR 7Q9) OR Navigation RNS (PR 7Q2) OR Auxiliary heater (PR 9M1 or 9M9) are fitted. In these cases please utilise part number 8P0 054 690
    2. Identify bodystyle of the vehicle i.e. 3 dr / Sportback
    3. Identify build month of vehicle
    4. Using a 5051, use address 16 to check steering wheel electronics – note the part number of the electronic module
    5. Once steps 1 – 4 have been followed, please refer to the attached spreadsheet to determine the correct unit to order and any additional parts
    In addition to the selection matrix on the attached spreadsheet, full costs and RRP are also highlighted.
    As it is impossible to tell which kit will be required for a vehicle prior to using the 5051 machine, we recommend that all 5 kits are ordered into stock prior to a customer’s vehicle being taken off the road. It should also be noted that whilst the quoted fitting times cover the fitment of the cruise control unit and additional parts, they do not allow for the time required to interrogate the vehicle using the 5051 machine. We recommend therefore that this is taken into account when quoting
    any fitting times and prices to customers.
    This is the info Audi UK give to dealers, im trying to post the pdf matrix document but not sure how to do it. Can anybody help?
    Si
    A3 2.0TDI S-LINE BRILLIANT BLACK (s-line suspension,Audi sound system) coming March (fingers crossed)!
    edition's Avatar
    Nov 2007
    1,417
    Yeah that pdf. doc. would be great
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by frenchy2475 View Post
    Si
    Email it over to me Si. PM sent with email address.
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by mattandrew View Post
    56 plate SE - 8P0 953 549 F
    edition's Avatar
    Nov 2007
    1,417
    Not looking good for my cruise is it! Without changing the module.
    Nov 2008
    389
    Mar 2012
    7
    Quote Originally Posted by phil_w View Post
    Hi,
    Any chance of uploading this again? If it is of any assistance and you care to PM me the PDF, I'll host and publish it for all
    W
    Mar 2012
    7
    Actually, it looks like this is the same thing:
    http://www.motor-talk.de/forum/aktio...hmentId=692222
    Nov 2008
    389
    Yep that's the one...
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    jsosic's Avatar
    Mar 2011
    Zagreb, Croatia, Croatia
    172
    Quote Originally Posted by woter324 View Post
    Hi,
    I had 1K0 953 549 AH in my car ( MY09 ), and it worked with cruise control. Changed it for 8P0 953 549 F as I installed MFSW. I have the AH module for sale if some is interested.
    And about sliprings, there are two sliprings, lowline and highline. Lowlines is installed in cars which don't have onboard computer. If you have onboard computer you have at least midline module which comes with highline slipring... so:
    lowline module + lowline slipring = nothing
    midline module + highline slipring = onboard computer + cruise control
    highline module + highline slipring = onboard computer + cruise control + multi-function steering wheel
    I have a midline module for 2004-2009 and highline slipring for 2004-2012, so if anyone is interested....
    Fossie
    Rhubarb Triangle
    3,969
    What info. are you requiring ?
