JMB RetrofitsSky Insurance
Page 1 of 2 12 LastLast
Results 1 to 40 of 55
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Retrofit USB port?
    Hi guys,
    Has anybody retrofitted one of these units to their cars? Do they work with ConcertII radios? If somebody would be so kind to perhaps provide a part number as well asa pic of the unit?
    TIA
    2012 RS3 / Daytona Grey / Alu pack / revo3+ / LOBA500P / LOBA CNC Intake pipe / LOBA HPFP / Forge Race FMIC / Milltek resonated exhaust / revo intake system / Devils own WMI / 20" BBS CH-R Titanium / H&R Monotube coilovers / H&R Anti Roll bars / Alu Roof rails / Hybrid RS grille / R8 paddle shifters /
    JohnS3's Avatar
    Oct 2004
    3,021
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Not quite the one that you posted. I have the Blaupunkt unit similar to the one you posted fitted in my car. It works fine but has been acting up lately. I read in an Audi brochure at a dealer that the OEM USB port can be ordered as an optional extra.I'm considering removing the Blaupunkt one and fitting the oem unit....if i could get the part number and possibly see what it looks like. Apparently it fits in the glove compartment.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    There are other types on ebay too.
    They plug into the same pins as the CD changer would IIRC and then you control it in the same way as you would with the ipod interface.
    EDIT: Sorry Rabbit I hadn't seen your second post. The OEM USB port sits in the glovebox like the ipod interface.
    8P2 S3
    27,072
    I was gonna fit the oem one but then John or someone highlighted the new AMI coming out so thought I'd wait for that tbh see if can fit & Leon is right its the cd interface for the basic current one.
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Thats the one Staz! You have a part number perhaps? Wonder if its a direct fit or will i need to replace something in the glove compartment?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by Rabbit222 View Post
    No part number I'm afraid sorry mate. I think they're inserts that fit in the top right area in the glove box. Obviously you'll need a hole for the cable. Should be easy!
    8P2 S3
    27,072
    Its just cutout needed in top of the glovebox & push into the hole & wire in cd wires in rns, I'm not sure if it comes with prewired connector or pins as havnt got etka/elsa reinstalled yet, but from all accounts its fairly easy job from what I recall, audiforums.us would maybe show images aswell Rabbit.
    JohnS3's Avatar
    Oct 2004
    3,021
    Looking in the brochure the USB connection has PR number UF2. Etka shows a glovebox insert for PR-UF2 as 8E0 857 925 E
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Thanks John, let me call Audi and see what they come up with!
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Part number is spot on John, part costs R2500 which equates to roughly 192 pounds.
    Cheers mate!
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Oh another thing! Is there a harness required for fitment or is this included in the unit?
    JohnS3's Avatar
    Oct 2004
    3,021
    I didn't see one. I'll check again for you.....
    JohnS3's Avatar
    Oct 2004
    3,021
    JohnS3's Avatar
    Oct 2004
    3,021
    Nothing conclusive, I could only find a cable to connect the CD changer to the headunit. But as the USB adaptor mimics the functions of the CD changer this may be the correct cable.
    JohnS3's Avatar
    Oct 2004
    3,021
    Why not put the R2500 (plus the cost of the harness) towards an RNSe? Then you will have two built in SD card readers and navigation?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by JohnS3 View Post
    8P2 S3
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    The thing is, RNSe is not freely available here in SA unless you know of someone that will ship to SA? Will the UK version work in my car ie: maps? What sort of pricing are we looking at in SA rands?
    Apr 2009
    Florida (previously Liverpool)
    655
    ...unless you know of someone that will ship to SA?
    I actually have nothing constructive to contribute here... -but that's one funny typo right there!
    Keith
    Scorpius's Avatar
    The S Factor
    Apr 2008
    South Africa
    82
    Tell us more please
    Also heard something about a new AMI but dont know any details around it and whether or not it will work with a Concert2
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Ninja edit FTW!
    JohnS3's Avatar
    Oct 2004
    3,021
    The UK/Euro version will work, but you'll need the SA maps which add further costs. You can source a unit from eBay for 500-600
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by Scorpius View Post
    Tell us more please
    MY2010 cars have the option of an upgraded navigation unit with a hard disk. This unit also has true AMI capability, ie track names/playlists from the ipod on the RNSe
    EDIT: Wont work with the Concert 2
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Cheers for that mate! Wonder what the costs are for SA maps....
    Iggu's Avatar
    May 2008
    Here
    1,224
    Here's the part number - don;t know the price though
    8P0 060 884 T (2008 ) South Africa
    Phantom Black S3, RNS-E with SDS Hack , BOSE, Sunroof, iPod, ITG CAI, Forge DV, Milltek TBE, Revo Stage 2+, Autotech HPFP, Sachs clutch, Lamin-X, BBS Pescaras, H&R springs, H&R ARBs, NGK Iridium Plugs, Vagcom.
    Iggu's Avatar
    May 2008
    Here
    1,224
  28. #27
    Scorpius's Avatar
    The S Factor
    Apr 2008
    South Africa
    82
    Ah ok. So not a simple addon then. Would have to get this new RNS-E with hard drive. I'm guessing its not available yet and so no part number to query for price. Maybe I'll just have to watch eBay
  29. #28
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Thanks Iggu! Price quoted R4000 exc vat!
  30. #29
    Scorpius's Avatar
    The S Factor
    Apr 2008
    South Africa
    82
    Theres a guy I was in contact with from Holland I believe (found him on the Naviplus forum) and he sold the RNS-E and could include the South Africa maps. Also could add adapters for DVD playback and voice recognition and bluetooth. Think it was a bit over EUR 1000 including shipping to SA (though it was a good while ago)
    Considering what I've just learnt I figure I rather wait and see how this new RNS-E pans out. Good iPod functionality is important for me and the old RNS-E doesnt address that
    The other alternative I'm waiting on is the Zenec unit. Zenec have just decided on SMAC as their local distributor and SMAC will soon have units available in South Africa with South African maps of course. Just hope they're reasonable on price
    http://www.zenec.com/index.php?id=294&L=1
  31. #30
    JohnS3's Avatar
    Oct 2004
    3,021
    That would be Haaggie
  32. #31
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by Iggu View Post
    And now sold.... Wonder who bought it....
  33. #32
    2008 Audi S3
    Oct 2007
    South Africa
    197
    SA maps in Audi SA cost around 3500 to 4000 rand (around 250 pounds), the discs for SA get updated every 2 years so next update only next year.
    The unit from Ebay is a good buy, I had a few friends who bought and installed it with no hassle. Some people take paypal, others you need to go through bank and transfer. Its plug and play. You can use the original disc or share the cost with a friend. There is a difference between the facelift and pre-facelist units but mostly cosmetic (silver surrounds for the volume control to match the new interior)
    The satnav is basic though, it doesnt allow speed camera alerts or anything else. Ipod control simulates a 6 disc cd player which maps to the first 5 playlists and all tracks on the ipod. This is if you plug the ipod connector into it, the USB connector will function similar. SD card reader in the RNS only reads SD (max 4Gb) cards, not the new SDHC cards so you might battle to get hold of them as well as SDHC has pretty much taken over here in PC shops. And the updates are every 2 years, a Garmin or TomTom is a better bet if you prefer to be up to date with roadnames. The 2008 map doesnt have many of the new road names as it is using late 2007 data when it was mastered.
    You are looking at around 6k or so for the unit landed, assuming customs are generous. If you get a dud unit its going to cost a fortune to send back so if you buy get it from a trusted source on Ebay.
    Personally, I'd wait for the new nav unit and forget the USB thing. For the price you said it costs its not worth it unless you planning on keeping it for a loooong time.
  34. #33
    27,072
    Hey Rabbit I've sent items around the world including FBMFSW's, I'd be willing to help you out if need be to alleviate any worry of dud unit, I can test & package etc, it wont be cheap to send insured, but cheaper than dealer stateside for you huh
    Few well known AS members can velch for me, if need help PM me.
  35. #34
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Thanks mate! This new RNS-E has me in a tizz at the moment. Maybe I should wait and see what they look like and then get into contact with you? REVO KEV can vouch for me as I have just been appointed a REVO dealer here in SA
  36. #35
    JohnS3's Avatar
    Oct 2004
    3,021
    They don't look any different apart from the media key. This is a unit in a Seat Exeo.
  37. #36
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Ok, took the plunge and decided to purchase the USB unit. It arrived at the dealership yesterday and I will be swinging by them today to see if it fits in the cubbyhole. Just need to make sure that I don't require anything else for fitment bar the CD Changer cable!
  38. #37
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Ok, swung by the dealership and had a look at the USB port. Its exactly like the one that Staz posted up...only one problem. Seems like I need to replace the inner section of my cubby hole as the inner section slopes whereas the USB unit is a straight unit if that makes sense. If at all possible, could somebody assist with the part number for the cubby inner section to enable me to complete the install without butchering my stock cubby hole inners?
  39. #38
    JohnS3's Avatar
    Oct 2004
    3,021
    I'll have a look on etka for you when I have a spare moment. Stay tuned!
    Can you post a pic of your present cubby hole/glovebox interior?
  40. #39
    JohnS3's Avatar
    Oct 2004
    3,021
    I have the factory ipod console, it looks like this. Is this what you need?
  41. #40
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    He's after the USB version John.
    8P2 S3
