Badger5AH Fabrications
Results 1 to 16 of 16
    ~RS~'s Avatar
    Feb 2009
    1,463
    MFSW retrofit- apologies in advance!
    I know this subject has been hashed out to death, but I must be getting duller as I age because for the 20 or so thread I just read on fitting an MFSW I am still no nearer to understnading what is needed!
    So, please bear with me and explain in 'for dummies' format what is required if I want to swap my steering wheel which looks like this:
    to one like this:
    (but S-line, chrome button surround version).
    The shape looks the same to me so I am hoping that I won't need a new airbag... but how do I find out if I need a new slip ring and ecu or not?
    I have a 54 plate 2005 sportback sport. No Bluetooth, RNS-E or phone prep that I am aware of.
    Damn! My head hurts reading about adding a MFSW!!!
    scottie123's Avatar
    Oct 2008
    1,888
    Have you got cruise control?
    I believe if you have this it may mean you have the correct steering ecu and slip ring
    The best way to check will be to contact your local dealer and give them your vin number and they will be able totell what ecu and slip ring are fitted to your car. Then post em on here and somebody will confirm if they are correct or not for mf
    You're airbag should be ok as it is a 3 spoke one and the mf is 3 spoke also.
    You will also need vag.com to enable the mf function on your car when fitted
    Oh, and i may have a sline mf wheel for sale if you arte interested.
    It doesnt have the chrome though. It is from a 2007 car
    05 SB SE BKD
    Build Thread
    ~RS~'s Avatar
    Feb 2009
    1,463
    Thank you very much mate.... That post did what an aspirin failed to!
    I do not have cruise control, I did read something to this effect but the thread died off so never got resolved. I will check with dealers on Tue... pm ya shortly
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    you got any pics of yours rs i want to see your wheels how they look on your car ...are they 19"
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,129
    Why don't you just get a flat bottom man?
    Bugsy_27's Avatar
    Vorsprung Durch Technik
    Dec 2008
    Everywhere!
    632
    Audi A3 2.0tdi S Line - Xenons, RNS-E, Bose, Black & Grey duo leather, MY11 rear lights, Shark Performance remap 183 bhp, Optics Grill with American plate delete, S3 Pedals, S3 vents, Weitec Coilovers, MY11 Black Edition FBSW
    scottie123's Avatar
    Oct 2008
    1,888
    Quote Originally Posted by N8KOW View Post
    Is that your preferance?
    I didnt know men came with differant styles of bottoms?
    05 SB SE BKD
    Build Thread
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    Quote Originally Posted by scottie123 View Post
    how much are you asking for it scottie, im after changing mine as i have the older one in my b6 cab and want to upgrade.
    do you have an airbag for sale too ?
    LOTS DONE, LOTS SPENT !!!!
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    how do you get the airbags off in order to get the wheel off if there screws where are they .....??????
    ~RS~'s Avatar
    Feb 2009
    1,463
    Quote Originally Posted by 10blazin
    Yes mate they are 19's my pic taking skills are in the category of rank amateur, they never seem to come out how the car looks! If that makes any sense or maybe it looks alot better in my minds eye
    How do you use this multi quote thing! It's doing my head in!!
    I want the RNS-E, bluetooth and wheel mod. Flat wheel costs are too prohibitive right now... maybe another time, I usually like things done all together and would have to wait a while longer to do flat wheel at the same time.
    ~RS~'s Avatar
    Feb 2009
    1,463
    Quote Originally Posted by 10blazin View Post
    Good question!
    How easy is it to swap wheels over? Is it a DIY or something I need to pay for
    scottie123's Avatar
    Oct 2008
    1,888
    if you look behind the wheel, there is 2 plastic covers about the size of a 20p piece. They are on opposite sides to eac other. Flip these of and when you turn your wheel, you should see a torque bolt . 2 bolts to take out.
    05 SB SE BKD
    Build Thread
    scottie123's Avatar
    Oct 2008
    1,888
    To remove the wheel you will need a m12 spline bit.
    Torque head ( not sure on size) to remove airbag.
    You will need vcds to code wheel to car if going from non mf to mf.
    If going from mf to mf , no need to code.
    Fairly easy to do, just make sure you dont move slip ring position when removing wheel , and all will be fine.
    havent actually done this yet!, but this is all info i have gathered from posts etc
    hope this helps
    05 SB SE BKD
    Build Thread
    pns2007's Avatar
    Nov 2008
    627
    As a matter of interest what does the slip ring look like, any pics ? please
    ~RS~'s Avatar
    Feb 2009
    1,463
    Anybody have the part numbers and cost of the ecu and slip ring required for the sw pictured above... one on ebay at the mo...
    ~RS~'s Avatar
    Feb 2009
    1,463
    Anybody know these part no's and rough cost?
