Results 1 to 17 of 17
Thread: boost pipe
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    Add martyboy on Facebook
    boost pipe
    thought i would start a new thread due to lack of replies no the the original!!!
    http://audi-sport.net/vb/showthread.php?t=70464
    anyway, was wondering, as i have a slight leak, is there anyway of making a better airtight seal where the boost pipe connects into the turbo housing. apparently the lugs have worn on the turbo side, meaning that even with a new boost pipe on, there is still a slight leak!
    does anyone know of anything to help with the seal?
    cheers!
    Just taken delivery of my Glacier White S-Line Sportback
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    If its the pipe that goes there, it would instantly blew off with the presure if it wasnt attached properly so the holders should be ok if thepipe doesnt blow off.
    as for the seal, did you replace the seal when the turbo pipe was replaced. maybe a new seal with some oil to double seal it should do the job.
    Maybe some knd of seal-tight glue?
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    Tetbury Audi Parts Man
    Feb 2008
    Gloucestershire
    260
    Quote Originally Posted by kaz219 View Post
    Yes I agree with you Kaz, the seal is a 3C0 145 117 it might be worth a try changing the seal. If its still making the noise I would guess a turbo. We have changed loads in here for making noises. Very common problem.
    Simon @Tetbury Audi
    A3 2.0TDI S-LINE BRILLIANT BLACK (s-line suspension,Audi sound system) coming March (fingers crossed)!
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    any ideas on the seal-tight glue i could use?
    dont know about the replacement of the seal as it was a garage that replaced the pipe!
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    Quote Originally Posted by frenchy2475 View Post
    Simon @Tetbury Audi
    when you say, changed loads of turbos for making noises, do you mean this problem that i have or other noises?
    and, what is a general ball park figure for the changing of a turbo, ie. new turbo and labour costs?
    thanks
    Feb 2008
    Gloucestershire
    260
    The usuall 'siren' type noise and excessive whistling. Alot of money through an Audi dealer. I know the turbo alone is over 1k as they don't list an exchange part number. Im sure you could source a recon elsewhere for less and get it fitted for under 1k.
    Going back to the seal, if they replaced the hose then that will come with a new seal already on it.
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    and do you know of any substance that could be added to this joint to make it a better seal?
    cheers
    Feb 2008
    Gloucestershire
    260
    Dont know of any myself, but they shouldnt need it.
    kaz219's Avatar
    Jun 2008
    1,796
    Just make sure the seal isnt pinched and put on right - that should do the job.
    If the mechanic is taking it off to take a look, you my as well replace it tbh.
    What makes you think there's a leak though?
    Vagcom'd too
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    had the engine pressure tested at a diesel engine specialist, and that was the only place there was a slight leak.
    fitter explained to me how the connecting 'lugs' can wear on both the pipe and the turbo housing and he says that its on the turbo side this time, which would have been caused by the lugs on the pipe side being worn the last time and moving back and forwards continually!
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    dont know if you got my pm but ive put a link to a new turbo for 350 on your other thread ....................
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    Quote Originally Posted by 10blazin View Post
    got it thanks! only problem is, cash!!!
    was hoping to get it replaced through warranty, as funds are a bit limited at the moment!
    overtime at work has been stopped for the moment and baby on the way, so warranty is my only hope of getting turbo done!!!
    thanks again for the link though!
    Feb 2008
    Gloucestershire
    260
    Im sure The metal clip on the turbo side which holds the hose in can be bought separately. They list a part number under the turbo number which just has a description with no pic. I will find out if this is the one tomorrow when im at work. 1J0145769F is the number for the clip, checked with another dealer who had it in stock
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    so do you think that replacing this clip on the turbo side will eliminate the leak and if so, what is the cost of this clip please?
    cheers!
    Feb 2008
    Gloucestershire
    260
    Well Marty it might be worth giving it a go, clip is 45p
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    can you supply this part?
    cheers
    Feb 2008
    Gloucestershire
    260
    PM me your address and I will sort it out for you.
