Volks AutosAH Fabrications
Results 1 to 40 of 40
    Feb 2009
    31
    Removing Steering wheel
    Hi All,
    got the parts to fit cruise control, but was wondering if anyone has the specs of the hex / star wrench I need to get the steering wheel off, I know its not a torx, but a spline, but what size anyone?
    G
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    M18 mate
    scottie123's Avatar
    Oct 2008
    1,888
    How easy is it to remove a steering wheel?
    Will vcds be required to reset anything once a wheel has been removed and swapped etc?
    05 SB SE BKD
    Build Thread
    Feb 2009
    31
    Ive seen it done when I was geting DIS retrofitted, quite easy IMHO. Disconnect Battery take off airbag then remove wheel ith Spline and wiggle it off ( remembering to mark wheel for putting it back on.
    If you are going to a MFSW then yes you will need VAGCOM and possily other parts sucy as slip ring and steering ECU depending on car, PM me your chassis no and I can check for you
    G
    2009 A3 Sportback Tdie (700miles to tank) retrofitted with Footwell and Puddle lights, Full ambient lighting, DIS, Cruise Control, Front Fogs, MFSW, Aluminium Scuff Plates
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    lol at the replies!
    scottie123's Avatar
    Oct 2008
    1,888
    So i've got a stutter....it aint my fault!
    05 SB SE BKD
    Build Thread
    27,014
    Then delete them mate as per Rob's request to us all, anyway I never discon battery & done it many times, but if you want peace of mind then go for it, take your time with parts, make sure you centre the wheel & when you remove the wheel tape the slip ring in position, do not let this turn at all, the spline & wheel are marked for centering anyway in the metal from factory, so easy to get fitted back correctly, but the slip ring must not be moved, can remove from column after tapeing in place.
    scottie123's Avatar
    Oct 2008
    1,888
    Posts are deleted. I was so busy laughing at howmany times i had posted in error that i forgot to delete them lol!
    Wheel removal sounds fairly straight forward.
    Going to order myself a m18 spine tool for the weekend.
    I have purchased a mf sline steering wheel of a 2007 a3.
    This is going to replace my current non mf wheel on a se .
    I have cruise control, so am i correct in saying that it will all be plug and play to get the mf working ok?
    Or is this wishfull thinking?
    05 SB SE BKD
    Build Thread
    27,014
    If you have MFSW now then should be straight swap if its A3 to A3 mate, cant see an issue at all, just make sure you dont turn on ignition until airbag all reconnected so as to avoid the airbag light coming up, you could discon battery for this as I have VCDS so I just turn of with this when it appears after work.
    scottie123's Avatar
    Oct 2008
    1,888
    i havent got multi function at the moment
    05 SB SE BKD
    Build Thread
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    What year is your a3, there is a possibility you will need a new steering wheel ECU and slipring. you are probably going to need VCDS to remove errors and reset steering angle etc etc
    Have a search in threads ive posted in regarding MF steering wheel fitting.
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
    scottie123's Avatar
    Oct 2008
    1,888
    It is an 05 sportback with cruise.
    05 SB SE BKD
    Build Thread
    27,014
    If you can give us the part numbers of the slip ring & steering ecu then we can advise if need other bits, easiest option is to ring local dealer, give them you're chassis number & ask them which part no's for the ring & ecu mate, easy peasy & takes 5 minutes if that.
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    if your taking the steering wheel off how do you take the airbag off first just pull it ....
    scottie123's Avatar
    Oct 2008
    1,888
    Quote Originally Posted by 10blazin View Post
    i think there is 2 torque screws that have to be undone. Access each one with the wheel at either 45 degrees left and then right .
    Well this is what the guide said anyway
    05 SB SE BKD
    Build Thread
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    well im thinking of getting a fbmfsw and want to know how do you get the airbag of then the wheel i have multifuntion already so would this be a straight swap ....
    scottie123's Avatar
    Oct 2008
    1,888
    cheers for th ehelp so far guys.
    I will give the dealer a ring tomorrow and find out which part numbers are fitted.
    I presume that if I ask the parts person for the part numbers for the steering wheel slip ring and steering wheel ecu, they will know what i am going on about
    will post back when i know
    cheers again
    05 SB SE BKD
    Build Thread
    scottie123's Avatar
    Oct 2008
    1,888
    MFSW to FBMFSW
    have a pick through this thread. Lot of info but i think by the sounds of it, you shouldnt need anything else as long as your new wheel comes with the correct wires.. i think!!
    Pretty sure the guys here will let you know though
    05 SB SE BKD
    Build Thread
    scottie123's Avatar
    Oct 2008
    1,888
    Well i managed to pop into the dealers today as i had a call out which took me right past .
    Very handy
    Numbers are
    slip ring 1KO 959 653 D
    control module 8PO 953 549 F
    so what do you reckon chaps?
    05 SB SE BKD
    Build Thread
    scottie123's Avatar
    Oct 2008
    1,888
    wheel turned up today also
    pictures show the old wheel and the new mf wheel.
    The other wuestion is will the airbag fit the new wheel ok.
    It looks the same shape so it has got to be as easy as that
    old wheel
    new wheel
    05 SB SE BKD
    Build Thread
    27,014
    Those parts are good to go mate
    scottie123's Avatar
    Oct 2008
    1,888
    excellent.
    So now to vcds. Will i need it when i swap over to mf wheel?
    I'm presuming I will but hoping i aint
    If i do , i may need to be making a purchase...... Still sorting that gb nhn? :P
    05 SB SE BKD
    Build Thread
    scottie123's Avatar
    Oct 2008
    1,888
    http://cgi.ebay.co.uk/FRANKLIN-TAMPE...1%7C240%3A1318
    is this the correct spline tool for steering wheel removal?
    just to check !!
    05 SB SE BKD
    Build Thread
    Feb 2009
    31
    Hmm, 4 spoke to 3 spoke, doesnt that need a new airbag??
    NHN, any ideas?
    Scotty, you will need vcds to enable MF
    G
    Quote Originally Posted by scottie123 View Post
    excellent.
    scottie123's Avatar
    Oct 2008
    1,888
    well i have been putting off buying vcds for a while now.
    Tbh , i really do need it
    Been driving round with the airbag light on for about a month after doing a dbl din conversion and not being able to reset the airbag light.
    So what is the rough price then for vcds.
    Nhn, am i correct in remembering that you were getting them for around 200 ishhh?
    If i need a new airbag though, this may change the outlook ! :P
    05 SB SE BKD
    Build Thread
    edition's Avatar
    Nov 2007
    1,417
    Anybody got any links to what i need to add cruise to my 3.2 2005 a3?
  28. #27
    Feb 2009
    31
    you can get a roos tech microcan for 199 delivered from www.gendan.co.uk
    Will do for the a3 no probs
    G
  29. #28
    scottie123's Avatar
    Oct 2008
    1,888
    thanks for that.
    Think i will order one , that is when some one tells me that me air bag will fit :P
    05 SB SE BKD
    Build Thread
  30. #29
    27,014
    Or you can get the hex can usb that does them all from me if I can get the price sorted from RT
    Simple really, just take your airbag of & see if it fits mate, but see if it has the cutouts for the 4 spokes underneath, if not then chances are it will be ok, interms of functionality I suspect it would work fine given dual stage anyway so that doesnt appear to be the issue there, just fitment.
  31. #30
    27,014
    just to check !!
    Thats a tad rich for one tool, just goto halfords cause they're tools are fairly good for these things, put it this way I have there big toolkit & none have had issues so far & the spline kit is great, has 6-7 sockets aswell so good for the VAG's cause they use few sizes on things.
  32. #31
    27,014
    Quote Originally Posted by edition View Post
    Depends on whats fitted to the steering wheel already, does it have MF?
  33. #32
    scottie123's Avatar
    Oct 2008
    1,888
    halfords it is tomorrow then
    i will try the airbag out over the weekend hopefully.
    What sort of time scale are you looking at nhn for the leads then?
    Oh , and the airbag, at the price for a new one, i will be making this one fit then lol!
    05 SB SE BKD
    Build Thread
  34. #33
    scottie123's Avatar
    Oct 2008
    1,888
    oh, one more thing...
    I presume it is ok the mechanically swap the steering wheel over and then code at a later date.
    It will be ok to drive etc in the between time, just the mf wont work.?
    05 SB SE BKD
    Build Thread
  35. #34
    27,014
    Just emailed Bruce@RT to see if can sort like asap really
    & yes you may have an airbag light but as long as you do as mentioned with the centering of the wheel & tape slip ring in place temp & make sure wheels not moved until new one on then all good, coding can do anytime & also remove airbag light anytime.
  36. #35
    scottie123's Avatar
    Oct 2008
    1,888
    ok cheers for that m8
    let me know if you get any updates
    05 SB SE BKD
    Build Thread
  37. #36
    Feb 2009
    31
    Cruise fitted, :-)
    Robin, wasnt M18, but managed to used a T55 torx anyway, Id say maybe a M16 or smaller spline.
    Scottie I think you are going to have a problem if your airbag is the same as mine, but saying that if you get it working PM me as thats my next retrofit.
    If it doesnt fit, let me know I have somone looking for a MF that looks like it would fit the bill. maybe do a quick deal, hopefully not but you never know
    G
  38. #37
    27,014
    Torx on a spline bolt, lol, hopefully not fecked it for future usage mate
  39. #38
    Feb 2009
    31
    Trust me I was Very careful, no apparent damage to the bolt
    Gonna order a new bolt and correct spline next time in in the dealers anyway..
  40. #39
    scottie123's Avatar
    Oct 2008
    1,888
    Quote Originally Posted by gregormac View Post
    Cruise fitted, :-)
    G
    Had a quicklook at the airbag today. I havent removed it, but it doesnt look promising.
    The are cut outs around the airbag to suit the 4 spoke style.
    It 'may' be possible to errmm 'adjust' the airbag by adding some new cut outs but no matter how you do it, i think it will look totally gash!!
    So i think i need a new airbag
    And the price of them may mean the s line mf will be getting sold and i will have to go and buy a fbmfsw. By the time i seel my old air bag etc , it shouldnt cost to much should it? :P
    so i may be up for doing a quick deal on the wheel if interested at right price....
    05 SB SE BKD
    Build Thread
  41. #40
    scottie123's Avatar
    Oct 2008
    1,888
    ohg and the m18 spline , couldnt get on in halfords that big
    think they may have had m16 though~ so now i know that is th esize needed ! :P
    05 SB SE BKD
    Build Thread
