Chris NottVolks Autos
Results 1 to 9 of 9
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    same springs? s-line springs wanted
    Does the A3 TDI SPORTBACK 5-DOOR HAVE THE SAME SPRINGS AS THE 3 DOOR MODEL ?
    Are the S3 springs ok to fit on a tdi,i like the ride height on the s3,or will they not fit?
    Anyone got s-line springs for sale off sportback?
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    i will have after monday .... mine is a 2.0tfsi qauttro sline sportback not sure if there any different for diesel maybe someone else can help.....
    I'mRonBurgundy?'s Avatar
    Lets make that kitten purr...
    543
    Mine are going, but they're off a 3-door, fwd too not quattro.
    2008 A3 1.8T FSI S-line Phantom Black, Bose, iPod Dock, Front Centre Armrest, Storage Pack, Aluminium Pedals, H&R Spacers, Eibach Pro's, Ambient Lighting, Pressed plates with Ingolstadt surrounds.
    Oct 2008
    Telford
    2,488
    Yes they are diifferent between the following
    3dr v 5 dr, This is because the back of the sportbacks are heavier so need a different spring rate.
    FWD v Quattro, kinda obvious, they are quite a bit different at the rear.
    B6 1.8T Avant s line gmbh
    Khufu's Avatar
    West coast of Scotland
    5,693
    Quote Originally Posted by Lee_R View Post
    FWD v Quattro - They aren't as different as you might imagine, most of the parts are the same - the actual hub being the main difference, unlike the 8L where whey were completely different. As you say though, the weight makes a difference too.
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    mine are what you need then unless theres difference between diesel and petrol springs ??? if yours is qauttro im assuming it is because of these posts?????????
    Oct 2008
    Telford
    2,488
    There are diffferences for axle weight your right blazin, The TDI's are heavier than the petrols so the spring rates are different, lowering your car used to be easy in the old days!
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    I dont think the weight is alot though dave r posted them in a thread it wasnt much ....
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    I have the complete suspension set up from my 2006 A3 2.0 PD140 qauttro laying in my garage. It was removed when i had coil overs fitted. PM me if interested. To answer peoples questions you will need diesel qauttro suspension as a diesel is more nose heavy and a quattro has a different suspension alignment then a FWD car does.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
