Totally Power Loss!!!!
p9lad
NULL
Hi Guys,
Has anyone seen this problem, this morning i opened my car as ususal turned the key into the ignition and noticed the dials were dead car would nto start!!! i took the key out retried to turn the ignition but nothing! so i got out the car locked the car manually with the key which worked then opened it with the alarm. turned the ignition on and it worked!
only thing that was weird was the clock reset it self, and the ESP light, Steering wheel, and seatbelt light was on. I drove down the road and all warnign lights switched off.
Anyone seen this b4??
have you disconnected the battery at all? cos sometimes doing that makes it go mad n resets everything, either that or you may have some wiring issues, bot too sure tho, am certain someone will be able to enlighten u!
564
674
681
555
