Badger5AH Fabrications
Results 1 to 10 of 10
    cameron1's Avatar
    Mar 2009
    56
    Changing Diverter Valve
    Well I picked up a new oem diverter valve from audi today
    http://www.goapr.com/images/20t_dv/20t_dv_oem_d_001.jpg
    and looked through previous threads to see how to do it. Warrencox had written some instructions for fitting the Forge version and it looked pretty straightforward.
    Unfortunately I am not too hot on the mechanics side of things, so after jacking up the car and removing the bottom engine covers I began to realise it was going to be a lot harder to undo the 4 torx bolts holding it to the turbo than I had originally thought.
    Has anyone tried undoing these bolts going through the wheel arch, or can anyone give a clueless idiot instructions as to how they managed to get these 4 bolts off please?
    Oct 2008
    888
    l take it your motor isnt a 8P
    Iggu's Avatar
    May 2008
    Here
    1,224
    Yeah dc240969 is right - you need to post this in the 8L section I think.
    Phantom Black S3, RNS-E with SDS Hack , BOSE, Sunroof, iPod, ITG CAI, Forge DV, Milltek TBE, Revo Stage 2+, Autotech HPFP, Sachs clutch, Lamin-X, BBS Pescaras, H&R springs, H&R ARBs, NGK Iridium Plugs, Vagcom.
    cameron1's Avatar
    Mar 2009
    56
    Yes it is an 8P - 55 plate 2.0Tfsi quattro sline
    Iggu's Avatar
    May 2008
    Here
    1,224
    Quote Originally Posted by cameron1 View Post
    Ah fair enough - apologies.
    My DV is at the front of the engine but I remember know that the S-Line has it located next to the turbo. Hopefully someone will be along to help you out. RobinA3 is a good bet.
    cameron1's Avatar
    Mar 2009
    56
    Quote Originally Posted by Iggu View Post
    Ahh that explains why I was having so much difficulty finding the damn thing, I wondered why the instructions I found didn't make any sense
    Anyone changed one of these on an Sline?
    cameron1's Avatar
    Mar 2009
    56
    Well a quick trip to Halfords to get a stubby ratchet and a small extender bar and managed to change it going through the wheel arch mainly (eventually).
    TBH I think the rev B one I removed was ok (just a bit noisy) - new one is quieter, but don't notice any difference in power delivery.
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    561
    Not looked on mine which is same engine as yours but seen one on an S3 and that was on front of engine i thought ours would be same
    cameron1's Avatar
    Mar 2009
    56
    Quote Originally Posted by phil76 View Post
    yea I hadn't realised either until I couldn't find it, that's why it took me so long
    2.0Tfsi Quattro S-line + remap
    warren_S5's Avatar
    Oct 2007
    7,163
    Fitting the 200PS versions is an absolute PITA. The torx bolts must absolutely bake with the heat they get from the turbo.
    Don't Forge / anyone else do a cold side relocation system for them?
    Having the valve so close to the turbo is madness given the fragility of the part.
    Audi S5 3.0V6T Coupe Black Edition
