AH FabricationsChris Nott
Results 1 to 16 of 16
    Littlemoss Lad
    Apr 2009
    Glossop, Derbyshire
    10
    Exclamation Heater Switch Panel Removal..
    Hiya guys, just a quickie, does anyone know how to remove the heater panel (where the 2 temperature dials and fan switches are) on the dashboard? It's the one just below the radio. I've had a feel around it but can't see any obvious way in..
    Thanks in advance, Dave
    Dave, Glossop
    edition's Avatar
    Nov 2007
    1,417
    It is just clipped in
    Give it a good tug.
    Littlemoss Lad
    Apr 2009
    Glossop, Derbyshire
    10
    ahh ok, i'm well practiced at tugging. Shouldn't be a problem but i might get scared!
    cheers buddy
    Dave, Glossop
    edition's Avatar
    Nov 2007
    1,417
    hehe glad I didn't offer a hand!
    Tommy's Avatar
    Makinen...ha
    Jan 2009
    Sheffield
    443
    Quote Originally Posted by littlemosslad View Post
    lol
    good old fashioned pull my friend
    27,099
    Remove radio & push from rear, note the trim fixed to bottom of the climate, also the arms to sides of the gear area, look underneath them for holes to remove via torx headed bolts & bolts hidden under the gear surround for the cubby hole trim/ashtray & the arms, I wouldnt try & pull from front, the sprung loaded metal clips are usually in there fairly well so from rear as such, the climate that is :P
    Littlemoss Lad
    Apr 2009
    Glossop, Derbyshire
    10
    cheers!
    Cheers everyone! Sorted it. It was I could get rid of an old phone holder which is now all done. cheers!
    Second question though all you brainy Audi fiends, how would i remove the radio? I know that sounds lame but even after getting the heater panel off I couldn't see an obvious way to get it out. The reason for this is my missus managed to squeeze in a second cd and now both won't come out. I've tried guiding one out with a thin filler knife whilst ejecting it but to no avail. So i'm thinking whizz out the radio and try to remove the top of it.
    It's obviously more slick than the old fashioned digi-clips or even the pioneer-type removal tools but i just can't make it out! d'oh! Please come to my rescue oh mega-experienced ones!
    :o) Dave
    PS, my tugging went very well thank you!
    Dave, Glossop
    27,099
    You need radio keys & get them from ebay or audi sell them as a pair but tad rich, so get of ebay for few quid.
    You should see very thin horizontal holes on the top & bottom lip of the radio front facing that you put keys into, then when all 2-4 keys are in dependent on radio type of course you can pull it out, then to remove keys to put back, behind key insert area you push in the metal clip retainer & you can release them to come out, do this carefully cause a slight flick of the key can scratch your radio fascia & you're be pissed about that & will want a new radio, seen number people do this, lol
    Littlemoss Lad
    Apr 2009
    Glossop, Derbyshire
    10
    Righto cheers. If I scratch it i'l just freak out a little bit, but not much..
    I'll check ebay tomorrow, nice one bud!
    Dave, Glossop
    Tommy's Avatar
    Makinen...ha
    Jan 2009
    Sheffield
    443
    If you want them quick and dont want to wait for postage off ebay, they sell the keys at halfrauds for a fiver (pack of 2)
    Littlemoss Lad
    Apr 2009
    Glossop, Derbyshire
    10
    'Halfrauds', cool..
    I ordered some off ebay last night so i'll have a crack at it when they come and let you all know in case anyone gives a toss!
    Dave, Glossop
    Littlemoss Lad
    Apr 2009
    Glossop, Derbyshire
    10
    got the keys...
    Hiya, well i got the keys, whipped out the radio and couldn't see an obvious way of opening the top lid of the unit.. I'll suss it when i have more time.. But, it appears I have a multi-cd changer cable going into the back of it but i'm 99% sure i don't have a unit. Pressing CD on the head unit doesn't say anything so i guess it might be for the amplified aerial.
    Anywhooo.. :o)
    Thanks to everyone for your help.
    cheers, Dave
    Dave, Glossop
    Littlemoss Lad
    Apr 2009
    Glossop, Derbyshire
    10
    Concert II Stuck CD sorted!
    Well, it's all sorted. The top of the radio just pops off with a small flat bladed screw driver. No screws required. The CD mechanism is easy to remove to. The two small torx screws on each side nearest the back and one on each side, inside near the front running vertically down the unit.
    And what the hell is this plug for? Is it the in car network thingy?
    And last but not least: These two black plastic things hold the cd inside so the need pushing down to allow a cd to be pushed out. I used a very thin filler knife to lift out of the cd's centre hole the mechanism's central spindle and then with my third hand (as it felt like thats what was needed) i pushed out the cd. Simples!
    Sorry for the crappy images, my G1 mobile's camera kinda sucks.
    The radio won't need recoding if it goes back into the same car and of course you need the special audi radio keys. I got mine off ebay and they're very good. Apparently the Halfrauds ones suck a bit as they bend very easily. Go for the metal ones if you can.
    Dave
    Dave, Glossop
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    My heater unit is starting to show a bit of age with scuffs and worn buttons - can you just replace it with a new unit plug and play or do you have to use vagcom to program it in?
    edition's Avatar
    Nov 2007
    1,417
    You can take them to bits and use your old internals
    I had to do this on mine as the new ones electrics didn't seem to work fully with my car...
    27,099
    Yeah they are plugnplay but note LHD then has the single control of both sides on the left, you know when you adjust drivers temp etc it also does passenger, facelift seems to be coded as only has one type in etka now, so result, but try finding bloody facelift version, like gold dust
