Sky InsuranceVolks Autos
    Apr 2009
    31
    Concert HU + 6 Disc Changer - Getting Aux In
    Hey guys
    new fourm member here, I just got a 07 Plate A3 - It has the Concert HU with a 6 disc changer in the glove box, however I have no aux in.
    What will be the easiest way to add aux in?
    Its a company car so i need to be able to return it to standard but i dont mind losing the changer for an aux in.
    can i get an aux in adaptor that will take the place of the cd changer in the back of the hu?
    If so which would people recommend?
    I was looking at this
    MP3 Adaptor
    Audi A3 2003 >
    Audi A4 2005 >
    Audi A6 2004 >
    Concert or Symphony on Quadlock connections, not with MMI.
    Important, please ensure black wire on interface is earthed before you connect the rest of the interface.
    CTVVGX004
    This MP3 connector lead can be used to plug your MP3 into your car audio system via the CD changer port giving excellent sound quality. Compatible with most MP3 models that have 3.5mm Head phone socket.
    cheers
    Apr 2009
    31
    getting an aux out would be even better actually
    JohnS3's Avatar
    Oct 2004
    3,021
    You have the double DIN headunit?
    JohnS3's Avatar
    Oct 2004
    3,021
    If so check your wiring. Does it have this pinout config? If you look top right you can see Aux-L, Aux-R and Aux-Earth.
    If so you'll need a couple of repair wires and either an old 3.5mm headphone lead or a posh Aux in connector. A quick bit of wiring into the quadlock and a vagcom recode and away you go....
