As some of you may know after having the Sachs clutch and flywheel fitted i have had a problem with changing gear quickly at high revs.
I took the car back to AmD for Shaun to have a look at. He had a look at the clutch and flywheel and it all checked out. To problem seems to be with the syncromesh in the gear box. This would explain why it has happened on completely standard cars.
For the gear box to be fixed its going to have to go back to Audi as its a very expensive part to fix. The best bit will be convincing them that it wasn't all my modifications that caused the fault, just brought it to the surface.....
Any idea's as to what the best was about going about this is? Any help would be much appriaciated!
