Chris NottMonster Motorsport
Results 1 to 13 of 13
    flyjakey's Avatar
    Fly..Jake
    Feb 2009
    leeds
    30
    ipod dock not workin with new nano Help!!
    Hi All i have just got my new 09 black edition with the ipod dock in the glove box it. The slides that they supply are for the old ipod nano and my 4th gen nano wont fit so it is wobbling around on its base also the nano wont charge so just goes flat But at least it plays ok ! Spoke to audi customer service and they just said there is nothing we can do take it up with your dealer we dont even know anything about it !! great service there then !! any one else in the same boat ?? Cheers
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    if i had a pound for the amount of times customer service have said id have 3 lol the twits but id take it back to your dealer and just get the cable fitted i have the cable in mine its fine ......
    flyjakey's Avatar
    Fly..Jake
    Feb 2009
    leeds
    30
    Think i will just go kick off get my money back for the ipod dock and get an aftermarket one fitted ! They should have told me before charging for something that only half works nob'eds
    26,762
    TBH have you tested an older ipod to make sure its not faulty 1st as they shouldnt have changed the pins really on the bottom of the ipod for charging as that would mean all pre ipod accessories wouldnt neccessarily work, apple are stigma for apple branded goods but they're not that anal for sure.
    I'mRonBurgundy?'s Avatar
    Lets make that kitten purr...
    543
    My 4th gen nano fits fine tbh and I've still got the slide that worked well with my 1st gen touch. That charged when docked but my nano doesn't. It doesn't charge when on my Bose Soundock in the house either so just assumed in was the ipod and not the car.
    2008 A3 1.8T FSI S-line Phantom Black, Bose, iPod Dock, Front Centre Armrest, Storage Pack, Aluminium Pedals, H&R Spacers, Eibach Pro's, Ambient Lighting, Pressed plates with Ingolstadt surrounds.
    Oct 2008
    20
    Apple have changed the charging pins, they swapped to new ones ages ago, but the latest range of iPods do not support the original ones any more. Same problem with my iphone 3G with my Sony in the Golf, but my old Ipod nano was fine. Known problem I'm afraid:
    http://www.caraudiocentre.co.uk/cara...-ipod-adapter/
    Feb 2009
    London
    180
    yep same problem with my iPhone, my iPod touch works fine with the cable.
    Feb 2009
    33
    Yep, new iPods DO NOT charge in "old" docks - thanks Apple . There is an adaptor available which is small and sits between the dock and the iPod to allow charging.
    I'll try and find it on t'net.
    Paul
    Oct 2008
    20
    Quote Originally Posted by A2A6 View Post
    Paul
    ^^ Check my post above!!
    26,762
    *******s, apple are ****s huh, I'm thinking a dismantle of the ipod adapter & move the pins or cut & move, this will resolve that issue easily
    flyjakey's Avatar
    Fly..Jake
    Feb 2009
    leeds
    30
    But should audi be making customers aware that no ipods made after september 08 will fit properly in the dock or charge dam right they should especially with what they charge for it !!!!
    26,762
    Yes they should indeed be making people aware, but on the flip side if the kit states which ipods it works with then guess they can say we did advise
    Oct 2008
    20
    It really is the manufacturers like Audi at fault, but they are certainly not the only ones! Apple specs for the last 3 generations of iPods have used the new pinout, but have also supported the old ones for backward compatibility. Apple have done as they promised and dropped the backward compatibility which should only break accessories a good few years old!!
    It's just laziness on the part of accessory manufacturers!
