mhill
Just found the draw under the drivers seat (perfect fit for my Road Angel Professional) but i though this was only there if you ordered the first aid kit, so im now left thinking have the dealers piked the kit? ive just tried using http://igorweb.org/equidec/Default.aspx to decipher the codes in the front of the service book but there is no mention of any of the optional extras that came factory fitted!
E4J = "S-line"
7A0 = Without CD changer/CD player
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
6X0 = Without entry grab handle
5SJ = Left exterior mirror: convex
5RU = Right exterior mirror: convex (large viewing field)
1KZ = Disc brakes, rear
J1L = Battery 280 A (60 Ah)
1LJ = Disc brakes, front
1AT = Electronic stabilization program (ESP)
3FA = Without roof insert (standard roof)
UA3 = Rear shock absorption
G34 = Front shock absorption
5TL = Decorative inserts in piano lacquer
7X0 = Without park distance control
4R4 = Power windows with comfort operation andcircuit breaker
F0A = No special purpose vehicle, standard equipment
8GU = Alternator 140 A
0YE = Weight range 5 installation control only, no requirement forecast
L84 = Suspension range 84 installation control only, no requirement forecast
TD6 = 4-cylinder gasoline engine 2.0 l unit 06J.D
3NZ = Rear seat bench unsplit, backrest split folding
8BP = Bi-functional headlight with gas discharge lamp
U1B = Instrument insert with mph speedometer, clock, tachometer and trip odometer
X2B = National sales program Great Britain
1N3 = Speed-related variable steering assist (Servotronic)
2PF = Leather trimmed multi-function sports steering wheel
8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
9Q2 = Multi-function display/on-board computerwith check control
SZ5 = Identification of "Budget" vehicles
D2L = 4-cyl. gasoline engine 2.0 l/147 kW 16Vturbo FSI, homogeneous Base engine is T59/T61/TQ2/TU2/TD6/TN6
7Q0 = Without navigation device
F18 = Alloy wheels 7.5J x 18
7K0 = Without tire pressure warning light
4X3 = Side air bag front with curtain air bag
3L3 = Manual height adjustment for front seats
VW1 = Side windows tinted green, from B-pillarto rear window gray tinted safety glass
3Y6 = Sun screen for rear window
4K2 = Radio remote controlled central locking "SZV"
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
1SA = Without additional engine guard
UG0 = Without hill hold control / hill descentcontrol / comfort driving assist
7MG = Emissions concept EU5
QG1 = Service interval prolongation
4GQ = Windshield in heat-insulating glass
E4J = "S-line"
