Sky InsuranceBadger5
Results 1 to 12 of 12
    K-Dash's Avatar
    Sep 2007
    Essex
    157
    Brake Pad Warning Light?
    This maybe a stupid question but do all A3s with DIS have the Brake Pads worn symbol display function?
    I have done a number of searches on Pads and brakes generally.
    My brakes are now squeeking and though its probably nothing I wondered if I need to replace any pads or discs.
    How reliable is this indicator?
    Audi A3 2.0 TDi Sport: Lava Grey
    • Bose Symphony II Sound System
    • Integral 6 CD Changer
    • Half Leather/Alcantara
    • Light package (Great!)
    • Parking Sensors
    • Eibach Sport Springs
    • OEM Sport Exhaust Tips
    • S-Line Spoiler
    • Genuine S-Line 18" Alloys
    • "OEM Style" Dension Ipod Dock
    FOR SALE
    NEW - BOXED - GENUINE - A3 HEADLIGHTS
    80 (the pair)
    JohnS3's Avatar
    Oct 2004
    3,021
    It should be very reliable, there is a wire embedded in the pad, when the pads wear down it breaks the wire and you get the light on the dash.
    K-Dash's Avatar
    Sep 2007
    Essex
    157
    ta mate,
    can't quite get what the squeeky brakes would mean then.
    Discs seem ok, no indicator on my DIS?
    I know it has been covered before, but there seems to be no conclusive answer. or am I missing something?
    • Parking Sensors
    • S-Line Spoiler
    FOR SALE
    80 (the pair)
    edition's Avatar
    Nov 2007
    1,417
    Stone stuck somewhere?
    Mine squeel alittle when slowing lightly at around 5mph....
    Just ignore it unless it's nasty, some cars do squeel
    JohnS3's Avatar
    Oct 2004
    3,021
    When you fit the pads, too much copperslip attracts brake dust, which can dry out the whole sliding pad assembly which leads to squeaks. Or one of the pads has seized and you have worn it right down to the metal. If you take the front wheels off and look in through the hole in the caliper you should see how much pad material is left.
    edition's Avatar
    Nov 2007
    1,417
    This is true there is only a sensor on 1 pad isn't there?
    On mine there is lots of pad left but still squeel sometimes mainly when the car has done alot of town driving...
    K-Dash's Avatar
    Sep 2007
    Essex
    157
    I considered the stone possiblity but the discs don't appear to have been affected.
    I've owned the car since September 07 and never replaced the pads (under the impression I only needed to when prompted by the DIS indicator)
    In this time I have chalked up 28k easily. Surely by now I'd need to replace them.
    They have only been squeeking a week or so but pads aren't expensive?
    Should I replace like for like?
    Should disc need replacing aswell?
    • Parking Sensors
    • S-Line Spoiler
    FOR SALE
    80 (the pair)
    edition's Avatar
    Nov 2007
    1,417
    Mine is just about to do 40k and have over 1/4 left on the pads........
    I got the car at 19k so i'm sure they are the original pads....
    I tend not to be too hard on brakes though....
    Khufu's Avatar
    West coast of Scotland
    5,693
    the brake dust off the pads can cause brakes to squeal. Its not impossible for pads to wear down to metal on one side but not trigger the warning due to uneven pad wear if the pad is stuck in the slides. I think if you remove the pads, clear slides etc and put everything back together with a little copperslip on the backs of the pads where they touch the noise will go.
    Oct 2010
    97
    Can't see that there's an answer to the original question - do all A3s with DIS have the Brake Pads worn symbol display function? And if so is it on both front and rear?
    Oct 2010
    97
    Quote Originally Posted by owenjt View Post
    Anyone?
    Fossie
    Rhubarb Triangle
    3,969
    Brake pad sensor is on front left only.
    Yes all A3's with DIS have worn symbol, and those without also have warning in cluster.
