EM TuningSky Insurance
    Sem
    Sep 2004
    297
    Change headlight washer delay, is it possible?
    Does anyone know if you can change the delay for the headlight washers with vag-com.
    I'd like to extend it for a few seconds as I don't want them spraying the headlights every time I use the wash wipe.
    Cheers.
    2008 (58) Audi A3 2.0TDI S-Line
    Phantom Black, Xenons, RNS-E etc...
    JohnS3's Avatar
    Oct 2004
    3,021
    Yes, it can be done.... Have a look at bytes 5 and 6 of the central electronics module
    http://en.openobd.org/audi/a3_8p.htm#09
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Yeah I have changed mine as I got through a litre of washer fluid in a week during the winter.
    8P2 S3
    JohnS3's Avatar
    Oct 2004
    3,021
    Just noticed you have a 08 car. If you enable advanced comfort features in your central electronics module (revision K or later) you can change the settings in the DIS!
