EM TuningChris Nott
Results 1 to 26 of 26
    S3-Dan's Avatar
    Quattro
    Mar 2009
    alnwick northumberland
    178
    High pitched whistle on acceleration ???
    i developed a high pitched whistle on acceleration tonight after racing a tuned to the hilt focus RS (and won by a fair bit hehe) im hoping itl be gone by morning when its cooled and its also idling a little high, anyone slightly more mechanical than me out there know what it may be ?? i did blank off the PCV the other day but had no problems until now .......................HELP
    Ibis S3 / GT3076R / 18" TD 1.3s Toyo R888's / H&R ARBs & Monotubes / USP LPFS / Turbosmart Eboost2 / WOT box / 500HP (EST)...and a TDI badge
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    Sounds like an air leak mate - check the work you done to ensure its properly sealed and no airs getting in...
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Mine has had a high pitched whistle between 4500 and redline since I bluefinned it. I thought it was normal. Do you think not kaz?
    8P2 S3
    26,720
    Quote Originally Posted by S3-Dan View Post
    Damn you should hear mine whistle & its only a TDI, mines turbo related & its fairly common thing on turbo's overall I believe after a while & if you've been hammering it.
    Might be a loose pipe but if you've got full power still seems unlikely its an air leak, any noticeable loss of power at all?
    S3-Dan's Avatar
    Quattro
    Mar 2009
    178
    wow thanks for the reply guys
    no theres no air leak and its at full power deffo NHN, its idling from 9000 to 14000 up and down and a little jerky so iv connected back up again and its still doing it now and still full power , id like to keep the blank on as its reccomended by a few guys on vagoc and doesnt affect it ''aparently'' so im unsure what the idling problem is now 'sigh' ....the engine warning light was on too but reset the ecu and thats off now, i wanna get to the bottom of the idling problem before blanking the PCV again
    any ideas kaz ? u seem knowledged up lol thanks
    Oh and the whistles gone now too but i hope it wasnt serious
    kaz219's Avatar
    Jun 2008
    1,796
    Quote Originally Posted by staz1000 View Post
    Mine whistles now but when i changed the IMF flap over, a seal between the egr and imf pinched and let air it. It whistled a lot louder.
    But normal turbos do whistle - mine was just a lot louder with the air leak and really juddery!
    But after myt remap, the turbo did sound different - a higher pitch whistle!
    Vagcom'd too
    warren_S3's Avatar
    Oct 2007
    6,093
    When the turbo is running at full power / temp for multiple runs I'd guess there could be a few things that may happen:
    1) Audi may have built in a fail safe to protect the car under certain parameters which causes the car to behave differently when it reaches certain temps / revs (you haven't taken it too far beyond 7200 I hope!)
    2) You have the startings of a boost leak which is accentuated under very high boost / temperatures. Once you car cools, the leak point returns to 'normal' (of sorts), and if the leak point gets bigger, so will the problem
    ALWAYS remember to warm the engine up considerably (around 12 minutes), and then COOL the turbo down (ie don't just switch off the engine after a rag - let the oil circulate round the system to cool things down a bit) by driving the car at normal rev ranges for 3-5 minutes after a 'heavy' session.
    I take it the car is throwing no DTC's?
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    S3-Dan's Avatar
    Quattro
    Mar 2009
    178
    ur right mitch haha why on earth i said 9000 to 14000 is beyond me haha of course i meant 900 to 1400 silly Dan altho a busa engine would be great haha my zx10r would go 14000 it did today anyways
    theres no DTC's mate but iv found the idling problem i took the spacer out of the forge DV and it lowered it a little and it split the pipe closest to the fan its connected now and goes great again the whistle stopped by itelf so i think one of your options was right warren
    big air leak, possibly why a porshe boxter just kept up with me gggrrrr tarty ba*tard lol
    iv redirected the actuator now so no pipes are close to the fan i was under the bonnet in the dark the other night so missed that split pipe somehow.....big sigh of relief
    warren_S3's Avatar
    Oct 2007
    6,093
    Well done mate, it's always horrible searching for boost leaks on turbo's as in the back of your mind you are always hoping its not the tubby thats on the way out!!
    A SEAT dealer wanted to replace a turbo on my last LCR (18 months old, 14,000 miles). Quoted an estimate of 3,700 for the job when they called to tell me their diagnosis of my boost spike issue (not warranty covered as car was modified). I disputed it, had it towed to an independent specialist, and after 10 minutes Vince at Stealth Racing noted the DV had a crease leak in one of the hoses that the dealer had failed to find in 3 days. Bunged him 25 in beer money and job was a good'un.
    S3-Dan's Avatar
    Quattro
    Mar 2009
    178
    jesus ! thats shocking mate !
    but ur right i kinda knew the tub wouldnt be on the way out its only 2 years old lol but cant believe i never seen that cut pipe maybe it was just split underneath to begin with ? yeah i think that was it haha not my eye sight
    im still in shock with your SEAT dealer story bud that is honestly scary !!!!
    i have a slightly scary seat story my friends ibeza FR diesal keeps up with the S3 THATS frightening but hes part exing it this week haha no more embarrassing races bloody light little fast thing !!!!
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,851
    hi there guys was wondering if this was normal.....say im driving in 2nd gear and let go the accellarator pedal (as you do) to change to 3rd gear i get a whistle like noise only its like a juddering whistle a bit hard to explain....also a heard the same sound from a golf which went past me yesterday and that was a 58 plate.Not very loud but loud enuf.
    My car A3 2.0 TDI SPORT 2006
    S3-Dan's Avatar
    Quattro
    Mar 2009
    178
    hmm never heard of that mate mind you most diesals do whistle on a lot and go for 300,000 miles being vag haha but couldnt say for sure buddy soorrreeee
    kaz219's Avatar
    Jun 2008
    1,796
    Quote Originally Posted by vw754 View Post
    Does it sound like a dump valve but a lot lower?
    I'm pretty sure thats normal as mine does it.
    Mine does it most when you accelerate to when the turbo just kicks in and you can feel the tourqe just kicking in and then lift off, it makes that noise more. im pretty sure this is normal.
    Vagcom'd too
    WiZBiT's Avatar
    Feb 2009
    332
    My turbo now whistles under heavy acceleration since the giac, it's nothing to worry about. Is your car stock dan?
    vw754's Avatar
    Nov 2006
    U.K
    1,851
    you guys drive ya tdi's in 3rd gear at around 40-50 and let go the gas pedal instantly and you should hear it.
    warren_S3's Avatar
    Oct 2007
    6,093
    My wife had a Revo'd Ibiza TDi FR running 168bhp. Went like stink, just didn't stop well (I warped her discs really badly!). Needed better suspension, brakes, and clutch.
    S3-Dan's Avatar
    Quattro
    Mar 2009
    178
    my whistles gone now guys it was just the night i raced a tuned up RS and took mine to the max up to ??? then eased off as my work was done haha he was nower to be seen but it was just as the torque was kicking in yeah then i discoverd the sliced PCV to actuator pipe after resetting my ECU to get rid of the engine managment light....an eventful cuple opf days haha
    but those ibeza's are stupid fast arent they lol my mate had mapped it to the hilt himself n i couldnt do a thing with it in a straight line, other mate has a cupra one mapped and it coasts past another mates R32 haha their a worry those little things !!
    WiZBiT's Avatar
    Feb 2009
    332
    Dan. 165mph on a pubic road? Are you mad, stupid or both??
    I don't think you'd stop in time for someone crossing the road
    Please consider your actions
    26,720
    Quote Originally Posted by WiZBiT View Post
    Where I agree that the speed mentioned is somewhat stupid & idiotic tbh, I dont think any of us can start criticising another member for speeds, I hazard a guess we all break speed limits daily which if we're honest wouldnt stop in time for someone crossing also so kinda kettle black springs to mind.
    WiZBiT's Avatar
    Feb 2009
    332
    Ok, So your agreeing with me then??
    The only critisizm I made was that doing 165mph was mad and stupid and you agree with me (see above)
    We can both the black pots together then
    WiZBiT's Avatar
    Feb 2009
    332
    Another point worth noting:
    Its not the best idea to start bragging how fast you went last night in Alnwick wiv yer mates, theres probably some low life grass on here waiting to let the coppers know what your up to.
    Just a bit of friendly advice
    WiZBiT's Avatar
    Feb 2009
    332
    Anyone remember this video by any chance??
    http://www.thisislincolnshire.co.uk/...l/article.html
    Jamiekip's Avatar
    Jan 2009
    710
    That's shocking - to think another enthusiast on a car forum would raise this to the police without speaking to the original poster first.... that's ****** in my opinion!
    I'm not saying I condone that sort of thing, but I guess in these sort of places you'd like to think you're with like minded people who would confront you directly rather than call the police...
    26,720
    I totally agree with you mate, all of the above
    26,720
    Quote Originally Posted by Jamiekip View Post
    Yeah I'd agree, why do people have to be so ****ty huh, if they had problem with there speeding they should of told them directly, but that Golf totally owned that RS4, does this start the old S3/RS4 row on a whole new footing, lol
    S3-Dan's Avatar
    Quattro
    Mar 2009
    178
    woaw woaw woaw who said anything about a public road ???? im from alnwick yes but in nowhere do i state its on a public road in alnwick mate
    someones jumping the gun dont you know how many private roads are around the countryside here ?
    im not daft OR stupid theres also plent of drag strips about too !
    and i suggest if u have an S3 and dont wanna use it get a robin reliant they dont go over 60mph !!!!
    sorry if iv offended anyone guys
