JMB RetrofitsBadger5
Results 1 to 10 of 10
    I cant spell !
    Jun 2007
    North West
    434
    Revo settings - anyone good ?
    I've just got my Revo select plus switch and I was wondering what would be the ideal settings - if anyone has done this to for an economy setting - ideal for cruising on the motorway at say 75 ish ? ie pretty much zero boost ?
    Richard
    MY12 Black edition TT Roadster with a tractor engine !
    mikep's Avatar
    Jun 2003
    Wetheringsett, Suffolk
    591
    You can set the boost to 2 or 3 for low boost, but it might take you a day or so to get to 75mph. Turn the Fuel setting down to 5 or 6, timing should stay at 4 for unleaded or 6 for super unleaded. I suggest you play with the settings until you get the economy you want. Make sure you save the current settings before you start playing.
    For performance, set boost between 6 and 9, Fuel to 9 and Timing to between 4 or 6 for unleaded to super unleaded.
    Hope this helps.
    Pragmatik ICT
    Revo (VAG & Porsche) & Steinbauer Dealer for Suffolk & N.Essex
    A3 Sportback 2.0TDi Sport DSG Revo Stage 1 & 2
    Porsche Boxster S Revo Stage 1
    I cant spell !
    Jun 2007
    North West
    434
    Cool thanks for that - certainly gives me a good starting point !!
    Have set the current settings to position B so can forget them !
    Richard
    KRL
    KRL's Avatar
    Jul 2007
    523
    Do you have VAG-COM?
    If you do take some logs and post them up, then I can advise you a little on what to do with your settings
    TBH I would really advise using VAG-COM if you are going to start playing around with your settings.
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    Jun 2008
    194
    fuel setting should always stay at 9 unless you have a fuel pump! boost is irrelevant, the car will only make as much boost as your right foot requests! and timing should be set to the fuel you run in the car! if the car is running in the most performance related settings the car will not need to be loaded up as much to get to that point and will be in its most efficient guise!
    it's all in throttle control!
    tobycruse's Avatar
    Jul 2004
    UK
    287
    Quote Originally Posted by revo carl View Post
    If you have a fuel pump what do you set it to then?
    Who said speed kills!?!?....But dangerous driving on the other hand....
    Ibis White S3 Sportback - ?bhp - ?lb/ft (Being Fixed)
    Mods: LED's Throughout, Milltek TBE, Revo S2+, Forge CAI (Gold), K&W V3's 25mm, H&R ARB's, Powerflex Bushes, Autotech HPFP, Sachs Clutch, Forge DV, Jonny's PCV Mod, Defi Boost Gauge, Pro Alloy Intercooler, 18" OZ Alleggerita's, NGK Iridium Spark Plugs, VI Performance Monitor, Road Angel Pro Connected
    Full OEM Springs and Shocks for sale from 2008 S3 CLICK ME
    Jun 2008
    194
    whatever you like mate,
    i still run them at 9 but if you want it to run a little richer you can!
    KRL
    KRL's Avatar
    Jul 2007
    523
    Carl,
    Could you expand a little more on why you recommend the fuel setting should be set to 9?
    My understanding is that sometimes it may be better to run a richer AFR especially if you are seeing excessively high EGTs.
    Jun 2008
    194
    the stock fuel pump cannot supply the car with enough fuel to make any good about of power so by setting it a a leaner desired value the car will be able to make more boost and produce more power. the EGT's at fuel 9 ar only slightly higher than stock
    KRL
    KRL's Avatar
    Jul 2007
    523
    thanks
