Monster MotorsportEM Tuning
    nick-barnes07's Avatar
    Jun 2007
    gloucester
    550
    looking at buying an a3 2.0t fsi quattro, what the difference from an s3
    Hi all, i have been thinking of buying a a3 s line quattro on a 06 plate, just wondering what the difference is between that and the s3, obviously apart from styling and interior, brakes, do they both run the same engine and internals??? i would be getting a s3 recaro interior and s3 bumpers for it, mtm bimottos and a gt35r kit when funds would allow and a bigger set of brakes ,
    liam's Avatar
    waiting, waiting, waiting
    Mar 2009
    Canberra, Australia
    170
    Same base engine, but the A3 has a smaller turbo and slightly different internals.
    I'll dig up some press blurb for you...
    AUSmotive.com | AUSringers.com
    Currently: 2004 MINI Cooper S & 2006 Mk5 Golf GTI
    Ordered 28 March: 2009 Audi S3 / Ibis White / RNS-E / Sunroof / FBMFSW / Heated Seats / Blackout Grille / Week 19 build / ETA July
    liam's Avatar
    Mar 2009
    Canberra, Australia
    170
    Like I said, this is press blurb, so there's not a lot of solid technical detail, but...
    TFSI in its most powerful form
    The power plant of the S3 delivers all that is expected of a powerful sports engine, and does so supremely well. The 2.0 TFSI, developed by AUDI AG, combines direct injection and turbocharger technology and delivers 195 kW (265 bhp) at 6,000 rpm. And at just 2,500 rpm it already musters up an impressive 350 Nm of torque this pulling power remains constant up to 5,000 rpm. In the combined driving cycle the 2.0 TFSI displays another welcome character trait, consuming just 9.1 litres of fuel over 100 km further proof of the forward-looking efficiency of TFSI technology developed by Audi.
    Compared with the A3, this engine is an advanced version featuring fundamental changes. The new turbocharger with its enlarged turbine and compressor rotor generates 1.2 bar of boost pressure an unusually high figure. A modified intercooler significantly lowers the temperature of the compressed air, thus increasing the air mass that is necessary for combustion.
    The new high-performance TFSI engine features pistons with stronger pins, while strengthened connecting rods with new bearings transmit the powerful forces to the crankshaft. The cylinder block has been reinforced, and the head is made of a new, highly heat-resistant alloy.
    The exhaust camshaft timing has been adjusted to accommodate the increased power output. High-pressure injectors with an enlarged cross-section squirt the fuel straight into the combustion chamber.
    For all its progressive technology, the high-performance turbo engine tips the scales at just 152 kilograms, less than comparable engines of direct competitors with a positive impact on the axle load distribution.
    To go with its sporty nature and firm handling, the new Audi S3 has a six-speed, close-ratio manual gearbox. Gearshift travel has been reduced for the S3, permitting even sportier and more precise gear changes. As is the case for all Audi S models, the new S3 drives all four wheels by means of quattro permanent four-wheel drive. An electronically controlled hydraulic multi-plate clutch, positioned at the rear for the benefit of weight balance, distributes the torque as needed delivering plenty of grip and maximum driving safety. All the drivetrain components have been strengthened to cope with the high level of engine torque.
    This text is taken from the original 8P S3 release in August 2006. AFAIK there have been no dramatic changes to engine spec with the recent facelift.
    V6Pete's Avatar
    Now running on Bentley's y'all
    Feb 2009
    Northants
    1,492
    That sums it up well. Even if you were to replace the turbo and intercooler later, you'd get up to S3 power, but the engine won't have the strong internals, so has more chance of going bang.
    Similar to the differences between the 150/180 and 225bhp 1.8T engines.
    A3 3.2 V6 S-Line | Brilliant Black | Full Votex Kit | 18" Cades Bern / 19" Bentley 5 Spokes in flat grey with 215/35 Falkens | Custom Code Remap
    V-Maxx coilovers | Remus exhaust | Pipercross Viper | Goodridge Brake Lines | RNS-E | Bluetooth | FBMFSW
    Previous VAGs: 99 S4 Biturbo | 06 Golf GT TDI | 08 A4 S-Line TDI PD140 | 02 Passat 4.0 W8
    Other toy: Suzuki GSX-R750 K3 Black/Silver
    Leather arm rest for sale | S3 mirror covers for sale | 09 3dr tail lights wanted | Twin grills wanted PM me!
