I'd have to assume from that observation it must be clipped in. Are there any obvious areas that seem to allow you to squeeze a blunt edged tool in and have a look underneath?
be carful you don't force it though as you may find that it doesn't go back on again and sit flush against the windscreen seal again - leaving a gap at the bottom of the windscreen - i had this issue with my last A3 and apparently the only fix is a new windscreen!!!
