Sky InsuranceAH Fabrications
Results 1 to 9 of 9
    Geordie
    Dec 2006
    Lancashire
    34
    Audi tools for filter change
    Hi Guys,
    My car which is a 2006 2.0 tfsi is shortly out of warranty and in future I'll be doing my own servicing.
    Looking at Elsawin it seems that to do an oil and filter change properly I need
    a) Oil filter tool 3417 which is a wrench to fit on the end of the canister (although a 36 mm socket will apparently do the job) and
    b)an oil drain adapter T 40057 which allows you to drain the oil from the filter housing before undoing the canister which stops oil spilling onto engine components.
    Does anyone know where you can obtain these from in the UK? (can't find a supplier via a UK websearch).
    Can you buy them from Audi?
    There are some suppliers in the US but I don't want to order from the USA if I can get them here.
    Thanks for helping if you can.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Just use a hammer and a flat head screw driver
    Press the screw driver against the notches on the oil filter cap and lightly hammer it
    Easy job and saves you buying a new tool (Y)
    Feb 2009
    Dallas, Texas, States
    you can also use the screw driver to just push in the filter drain plug and let it drain that way so you wont need the filter drain tool its a pos anyways
    A3 3.2Q Ti Sportback Avus Silver
    HPA\\\ DSG Stage-2
    TT-S Flat bottom steering wheel, Euro LED tails
    PW-Motorsport's Avatar
    Jun 2006
    Pembrokeshire
    389
    I have the correct filter tool for sale.
    Have a look here,
    http://cgi.ebay.co.uk/Gen-VW-Audi-oi...713.m153.l1262
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Are they not just for the 1.9tdi metal filters?
    Jun 2006
    Pembrokeshire
    389
    Quote Originally Posted by Boydie View Post
    It also does the 1.9tdi plastic housing as well as most of the OE metal filters.
    Geordie
    Dec 2006
    Lancashire
    34
    Hi PW- Motorsport,
    Thanks for that. One on order. Just need oil drain adaptor T 40057 now.
    Jan 2009
    106
    The bleed tools are about 40.00 IMHO a complete and utter waste of money!! Come around to mine and I'll change the filter for 10.00 for you that way you save 30.00....Or read this, stick a screw driver and push the valve to one side (as all audi techs do!!) let it drain and then push it again to click it back into position. Taht way it won't cost you a penny....
    http://homepage.mac.com/cvervais/gli/20tOilChange.pdf
    regards
    dave
    A3 2.0Tfsi D.S.G Sportback. Leather, light and rain pack, Interior light pack, bose, bluetooth, 6cd, multifunction wheel, cruise, Heated front/rear seats, Folding mirrors, rear parking sensors , ipod connection in glove box, open sky roof, dual climate, sun blinds, electric drivers seat,
    Geordie
    Dec 2006
    Lancashire
    34
    Thanks Guys for your help. Have been doing own servicing for 50 years (yes 50 years !! - I'm an old timer !!) but this is the first oil and filter change on an Audi. (First car was a Standard Eight.) Looks straightforward and Elsawin and the link make it dead easy.
    Thanks again.
