Chris NottAH Fabrications
Results 1 to 39 of 39
    APL TDi's Avatar
    Jan 2009
    285
    2.0 tdi fuel filter replacement
    Hi all
    I have never serviced a tdi before. Can anyone point me in the direction of the fuel filter please?
    Thanks alot.
    Ant
    2004 140 TDi sport 3dr (new turbo)
    Oct 2006
    Malvern
    51
    Looking at the engine bay,
    Left hand side,
    About 12 inches (30cm/300mm) from the headlight towards the rear of the car,
    Canister looking thing, with 4 pipes on the top, 5 ? torx head screws holding lid on, and one in the middle to bleed/water seperate.
    Good luck!
    Everyday:
    Audi A4 3.0 TDI quattro - 2008, Panther Black
    Upgrades: Planning in progress !!!
    Weekends:
    Audi ur quattro - 1989 (was 2.2 5cyl turbo, currently evolving to 3.6 V8 twin turbo!)
    Registered VAGCOM user.
    APL TDi's Avatar
    Jan 2009
    285
    Ooooh, THATS the fuel filter! lol
    Thanks very much mate
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,770
    Easy peasy to replace but maybe have a bag at hand when taking it out as it will be full of fuel
    Also, do not worry if it takes a wee while for the engine to start as there is no fuel in the new filter!
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Turn the ignition key a few times before starting and the system should self prime.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    mcconnot's Avatar
    Sep 2009
    75
    OK, perhaps a silly question... When i remove the 5-6 screws off the top of the fuel filter will it squirt fuel at me. If the car is turned off will the fuel filter housing still be pressurised or slightly pressurised?
    Thanks.
    Tom
    Boydie's Avatar
    Boycie
    Dec 2006
    4,770
    It will a bit but it won't blind you!
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Is it just a case of lifting the lid, replacing the filter and tightening the lid again, or do you need to use the bleed screw to bleed it afterwards?
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
    mcconnot's Avatar
    Sep 2009
    75
    Quote Originally Posted by alfiejts View Post
    Could someone give a detailed description of the filter change procedure. I have searched all threads but most just say, take the lid off, yank the filter out and screew the lid back on. Turn engine on and it will be good to go.
    Are there any little niggles like being ready for it to squirt or having to bleed afterwards as amentioned above.
    Boydie's Avatar
    Boycie
    Dec 2006
    4,770
    Basically that is all you do - it will take a bit longer to start as there will be no fuel in the filter but that is normal.
    Unscrew, remove old filter, replace with new filter, screw, turn on engine.
    mcconnot's Avatar
    Sep 2009
    75
    Quote Originally Posted by Boydie View Post
    Would it help to fill the new filter up with fuel before putting th lid back on. Or is it really not necessary?
    Thanks by the way!
    Boydie's Avatar
    Boycie
    Dec 2006
    4,770
    Not necessary. I didnt anyway when changing it.
    No problem
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Mines going to take a bit longer as I want to sand down and paint the top of the filter whilst its off. Its the only thing that's rusted under the bonnet. Someone must have left some standing water in it during the car's first 12 months before I bought it....
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Swapped mine yesterday. The motor factor had two different filters and even knowing the engine code and chassis number, it could still be one of two, so I had to take the old one in to get the right replacement.
    I was in Halfords later and the one they sell for the A3 is the same as mine - except I paid 15 from the motor factors and they charge 26...
    Mine also came with a replacement seal for the cannister lid and also a replacement seal that looks like the five olympic rings, that went onto the top of the plastic moulding inside the cannister.
    I did have trouble getting the lid back on the cannister. I had to force it down quite hard - and eventually loosened the bleed valve to help...
    Its all back together now, but I am having a nagging doubt - The filter itself has a grooved ring at each end. I'm wondering if that was meant to locate on a slot at the bottom of the housing. I couldn't see to the bottom because it still had fuel in it and I didn't try and turn it to see if it aligned into a slot - I just pushed the filter in and forced the lid back on....
    Now I'm not sure whether to take it apart again and to try and align the slip in the filter with any rib on the bottom of the cannister.
    Can anyone advise?
    mcconnot's Avatar
    Sep 2009
    75
    Done mine yesterday too. i dont think it had been replaced in about 80K miles. the filter was black as coal!
    buy yeah it was just as case of taking the lid off, pulling out the filter and pushing in the new one with a new rubber ring going on the underside of the lid, a new 'olympic ring shaped' rubber seal on top of the new filter and a new metal washer on the outside of the bleed screw. It took a bit of force to get the first screw back on but after that the rest of the screws just pulled it down!
    Am i mad in thinking that the car actually feels a bit more responsive and smooth since changing it? It feels like it is. Its definitely smooter running since i done an oil, fuel and air filter change along with an il change.
    Dec 2009
    Hi, just changed my fuel filter and it is also really black, is this normal or something to worry about??
    Crunch's Avatar
    Jan 2009
    117
    I'd worry when you pull out the old filter and it's pink
    26,774
    It will get black over time from the fuel impurities anyway, thats the point mate, nothing to worry about, I mean how many miles has it done?
    Dec 2009
    Sorry to take so long to reply, ive just been to the south of france, the cars done 75000 miles and as far as i know this is the first time its been changed.....
    I just wasnt expecting it to be so black, i will probably give it a few more miles and change it again to see if its black again.
    Ste
    26,774
    I wouldnt bother mate, waste of money IMHO, but your choice, give it another 20-30k then change.
    V16
    V16's Avatar
    214
    quick question even though its stupid!
    just bought a fuel filter and going to fit it. my drive is on a slope, with the bonnet facing downwards.
    does this make any difference or should the car be on a flat surface?
    Black A3 S-line 2.0TDi
    Mods: Hybrid Turbo - Custom Exhaust - Weitec Coilovers - Tints - Gloss Black Optics Grill - Led Number Plate Lights - Led Interior Lights - S3 Mirrors - Retro Fitted Arm Rest - 09 rear lights - R8 Oil Cap - Phillips Diamond Vision Lights
    26,774
    As long as has enough fuel in then isnt an issue, assume you understand how to bleed it to fill the filter & remove air.
    V16
    V16's Avatar
    214
    mmm from reading above i thought it was just these simple steps?
    tdi-man's Avatar
    Jul 2009
    1,588
    i changed mine the other month but how do you bleed the fuel system as ????
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    26,774
    There is a screw on the top of the filter casing, leave this of, turn over the engine with the power pack disconnected from the right side of the block, then when the fuel starts running out of that screw then screw it up & job done, reconnect engine power pack & start her up, you probably would be ok without doing this but I wouldnt chance it.
    tdi-man's Avatar
    Jul 2009
    1,588
    oh rite so if i didn't do it when i changed filter should i do it now ? or would it of bled it self ?
    thanks
  28. #27
    Wozski's Avatar
    480
    what do you mean reconnect power pack??
    Thining of giving mine a mini service...
  29. #28
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Anyone know the cost roughly of the TDI fuel filter? Just so I know what's cheap etc on bay
    Moved to the Darkside click below:
  30. #29
    Jul 2010
    Merthyr Tydfil, United Kingdom
    846
    Quote Originally Posted by Smoothie View Post
    No more than 25 are they?? They were about 19 from the dealers for my old MK4 Golf so can't see them being much more expensive if at all
    Now a happy owner of an A3 Sportback S Line 170 TDI
    My Posh Golf
  31. #30
    26,774
    Quote Originally Posted by Wozski View Post
    Read the whole thread mate.
    About 20-30 but be aware there are 2 types.
  32. #31
    Wozski's Avatar
    480
    nige i have and am still none the wiser??
  33. #32
    26,774
    On the right side of the engine there a round electrical power connector, this is disconnected whilst priming the fuel delivery system, it stops the car from starting, thus once you've primed by turning the car over a few times you then reconnect & start the car, job done, well this is how I do it anyway mate.
  34. #33
    Wozski's Avatar
    480
    lol ok i thought you could do that by just switching the ignition on - without starting the engine??
  35. #34
    Wozski's Avatar
    480
    the outer pipes are connected with some clips are these easy to take off?
  36. #35
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    no problem mate, trip to the dealers me thinks
  37. #36
    Wozski's Avatar
    480
    Well i had a spare day today so i painted the outer lid. Was a pain to clean and paint as i couldnt wire brush the more affected areas of rust etc. I painted it with trusty old hammerite smooth silver. Im not impressed with the results if im honest but it looks better than it did!!
    One question is there a special way to remove the filter itself as i tried when i had the cover off but it wouldnt budge.
    thanks
  38. #37
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,852
    pull!
    Full leather/19"wheels/cruise/
  39. #38
    26,774
    Very hard
  40. #39
    Wozski's Avatar
    480
    LOL ok thanks guys - if anyone is interested i can post the pics tmw sometime.....
