EM TuningBadger5
Page 3 of 3 FirstFirst 123
Results 81 to 116 of 116
Like Tree2Likes
Thread: Converting symphony II antenna system use with RNSe
  1. #81
    The Governor's Avatar
    Mar 2012
    Southampton
    436
    Cheers Nigel, I thought I might have saved myself a few hundred quid on my future job there, ah well, nearly
  3. #82
    Jan 2012
    1,837
    By using this guide last night, I successfully added the ZF to my 2009 after installing the RNS-E MK2 a few months ago.
    A big shoutout to JonS3 (the OP) for the thread and jb0o for sourcing the little amp for me.
    Cheers guys! :D
    Happy Christmas
  4. #83
    Oct 2012
    SW London
    16
    Huge Thanks to JohnS3 for working this out and posting the how-to guide!
    I changed the Amp and booster today and it's greatly improved FM reception on my RNS-e.
  5. #84
    Mar 2012
    Southampton
    436
    Does doing this change improve the FM reception for all head units?
  6. #85
    27,099
    This is only for late 06/07 onwards people that convert from concert, symphony, chorus, 2+ units to rns-e.
  7. #86
    Mar 2012
    Southampton
    436
    Thanks NHN, the FM reception on my 2011 BE is pretty bad really, I was wodnering how it could be improved...
  8. #87
    27,099
    Sounds like you either have a faulty amp or wiring, whats vcds say?
    I could swap parts over & run temp cables to test the system, could even be the rear screens/antennas mate, but if its under warranty take it to audi.
  9. #88
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Bit confused by this as the lower amp listed in the parts list has no suffix at the end, yet every lower amp I've come across has a suffix (D). Am I missing something here?!
    A3-8PA likes this.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
  10. #89
    Jan 2012
    1,837
    If anyone needs an upper amp I have one for sale .. £10 and its yours.
    This conversion is worth it, ones of the best I've done.
  11. #90
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    448
    Hey Chris,
    Is that the 8P4 035 225B Upper antenna amp?
    New or used?
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
  12. #91
    27,099
    £10 is a bargain, they're £24 for new.
  13. #92
    Jan 2012
    1,837
    It's new, but obviously second hand. But has never been used as I sourced one from Jonny while this one was in transit from Germany.
    It starts 8P3 035 225B but is identical to the 8P4 035 225B one I have fitted.
    First to PM has it
  14. #93
    339
    Is there anyway to tell the amp numbers without first taking off the boot trim? I've got a SB, but the linked guide on trim removal is dead.
  15. #94
    339
    Had a chance to read through better, basic understanding is that you have to
    • Switch out the upper and lower amps
    • Reconnect the two FAKRA cables on the old lower amp to the new lower amp
    • Connect the two new amps using the yellow three wire loom (that you have to make)
    • Connect the FAKRA cable that was connected to the old upper amp to the new 3rd FAKRA connector on the new lower amp
    What I am missing is why you need two new FAKRA cables, one 0.3m male to male and a 1.5m extension cable? Implies you are making two new connections, but not sure what to what? Had assumed these were to allow you to run the FAKRA lead from the upper to the lower amp without un-picking the loom, but why two separate cables?
  16. #95
    Oct 2012
    SW London
    16
    Quote Originally Posted by elrao View Post
    The two Fakra cables are connected together to make a single cable, long enough to reach between the amps. They are standard length cables available from a dealer, alternative is to have your own cable made up specially.
  17. #96
    339
    As it says you can get away with a 1m female to female and the 0.3m male to male then am guessing a 1.5m male to female would work?
    2m cable on eBay is about £12
    http://bit.ly/ZojMT4
  18. #97
    Jul 2013
    9
    Hi
    I have just mounted rns-e in my audi a3 8p modeljahr 2011. Before I have concert-radio. I also want to change the diversity antanne system so the no error in vdcs and better signal. I have planned to use the instructions in the thread but have i problem.
    On the lower amplifier I only have one fakta( the White fakta - see Picture one) and not the gray. so want to do. I have taken some Pictures please have a look.
    Best Regards
    Mikkel
  19. #98
    27,099
    Welcome to the site Mikkel.
    That's normal for newer 8P's, can still mod the car for this antenna system, did you buy the kit or you wanted one supplied?
  20. #99
    Jul 2013
    9
    Thanks for the Quick answer. I have just bought the upper and lower AMP. So miss cables. Can i just follow the guide and no need for the gray fakra?
  21. #100
    27,099
    You need to connect all as described, so buy the cables & connect it all up.
  22. #101
    Jul 2013
    9
    I an not sure that i understand. Sorry
    in ny eksisting system aa showed om picture i dont have the fakra gray fakra cable. How to handle? In guide the existing system have both a White and Grey fakra... And after mod Also yellow
  23. #102
    27,099
    The new amp has 3 connectors, you connect to one of them as per the guide above, you dont need to worry about the grey cable.
  24. #103
    Jul 2013
    9
    nhn - do you know a place in Europe to buy the parts except the amps and Price. Parts are very expensive in Denmark
  25. #104
    27,099
    How expensive can it be for the cables in Denmark?
  26. #105
    Jul 2013
    9
    About 95 EUR inkl tape
  27. #106
    27,099
    What's the problem with that?
  28. #107
    Jul 2013
    9
    It is exclusive amps
  29. #108
    27,099
    So, you have the amps already, 95 euros isn't exactly expensive to get it installed & working is it, time = money & the more time you spend on finding something 10, 20 or so euros cheaper is imho a waste of time, if it means you get the system completed then pay the 95 euros, I fail to see the issue tbh.
  30. #109
    Jul 2013
    9
    It is only for parts and i install myself. Installation is not included in the 95 eur
  31. #110
    27,099
    & again I say, I cant see why paying 95 euros for these parts is a problem, am I missing something here?
  32. #111
    Jul 2013
    9
    If i look at first page it is around 30 EUR/gbp for the parts. Remember i not need the amps. I have them
  33. #112
    27,099
    Its not 30 euros, its £50 as I have the uptodate prices here, plus postage from UK, so that will be about £65, equated into euros isn't far of 90 so for me, just pay the 95 euros locally for peace of mind.
  34. #113
    Stol1975's Avatar
    Sep 2012
    227
    Just done this fix. I have my radio back got the parts from Dave at stoke Audi via this forum. So just a quick question, now I have all the traffic info available to me does the satnav take this into account if a road is blocked or do u have to manage the re-routing yourself?
  35. #114
    coxy8329's Avatar
    Nov 2011
    Hampshire
    166
    Quote Originally Posted by Stol1975 View Post
    Sometimes
    Audi A3 Sline 170 2.0 TDI
    Mods Done
    RNS-E mkII fitted, Tinted Repeaters, Center Armrest,
    LED Interior Lights, Cruise Control, LED Number Plate Lights,
    VW fan windshield washers, S3 Pedals, Metal Footrest,
    DPF & EGR delete, Unicorn Remap, De-badged the tailgate.
    With DPF Without DPF
  36. #115
    Jul 2013
    9
    Hi
    I followed the guide in a 2011 model and Can confirm that it work even though the 2011 model dont has the Grey cable, only the white
  37. #116
    Dec 2013
    Hello,
    I've been following this thread for a while and wondered if this modification works on a MY08 TT coupe.
    I was quite bullish and went and bought all the required bits before realising that the TT has a different lower amp. My car doesn't have the shark fin antenna as it was never factory fitted with the RNSe.
    Is there any way I can make this work? If not then as I said I have all the bits required if anyone is interested in doing a deal...
