The dreaded coolent warning came on the other day. The car is an A3 2.0 TDI (2004). I topped it back up to inbetween the maximum and minimum and it dropped to bang on the minimum line after approx 110 miles (so not a huge water loss, but still significant).
I took it down to the Audi specialist today and after 1 hour on the pressure test it didn't show up any loss of pressure. I spoke to two garages and the general consensus is that I should drive the car around and monitor the coolant loss and oil level (to check whether the oil is going through the head). Quite frankly I do not even want to contemplate the fact that it could be leaking though the block
My question is whether anyone would do anything differently or look out for anything else inparticular (I am aware that several of you will have already been through this experience). I expect to do almost 1000 miles in the coming week so the last thing I need is to risk damaging anything else like the turbo.
I am tempted to change the header tank first as I have never been too happy about that being literally two pieces of plastic glued together, and from what I know of a pressure test a leak in the header tank would not show up.
Quite frankly part of me wants this problem to be the cylinder head so that I can get rid of this horribly weak pourus head which has been bugging me since I found out about it (unfortunately after I purchased the car!!).
Any thoughts are most welcome.
