Sky InsuranceAH Fabrications
    antonio87's Avatar
    Feb 2009
    33
    RNS-E IPOD ADAPTER HELP
    just got an original ipod adapter for the rns-e (8E0051444A) tryed to install it this afternoon but had no luck. the instructions make no sense to me and have no idea how to set it up.
    anyone installed one on their rns-e any tips?
    any kind of help much appreciated
    JohnS3's Avatar
    Oct 2004
    3,021
    It plugs into the CD changer port in the loom, or replaces your existing CD changer if you have one. If you have an 07 car or later then it should plug into the quadlock, if it's an earlier car you should have mini ISO plugs to deal with. It's very simple to operate, pressing CD number 1 to 5 on the headunit gives you the first 5 alphabetical playlist, CD6 gives you every track on your iPod.
    Dec 2004
    287
    You've got the wrong kit. You need 8E0051444B for Quadlock Connector Radios.
    2008 VW Golf R32 3dr
    DBP :: RNS510 :: Winter Pack :: Retrofit Cruise :: OEM LED Tail Lights :: R-line badges ::
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    If it has a 'flying' ground lead these normally have to be connected to the radio chassis too.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    antonio87's Avatar
    Feb 2009
    33
    thanks for that guys. i spent so long on it just looking at it and trying to make sense of it. ill have to take it back to audi and get it changed. thanks again
    Dec 2006
    11
    quick question as im trying to fit my ipod kit, how did you guys remove the brown coloured wire from the original quadlock adapter so that you can replace it with the brown fly lead that is on the ipod cable as i cant seem to be able to remove mine
